Here is alink to the wiring digrams fo the vehicle. http://bbbind.com/free_tsb.html
It's tan . An it's five volt reference voltage .do you know about reference voltage ? The PCM supplies this voltage . The tan / black wire is a ground through the PCM . 5 volt reference
The iat is part of maf sensor. The iat gets 5 volts ref from the computer.
Hope I got the correct wiring diagram? I try to be accurate.
SOURCE: 1991 Mazda Protege IAT Sensor location
Side of air cleaner housing. Check this link & click on picture to expand.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c15280039904
SOURCE: what color are the wires for the iat sensor on a
the iat is part of the maf sensor located in the air filter duct or housing. 6 pin connector. pin one color violet/gray is for iat. pin 2 is c-signal rtn yellow/violet. pin 3 maf yellow/violet. pin 4 maf rtn blue. pin 5 ground black/yellow pin 6 circuit breaker fuse 76 blue/brown
SOURCE: wire colors for my IAT sensor
red with blue stripe and black... cut the red with blue strip and connect one end of the resistor to the harness side. Then splice the other end of the resistor to the black wire... do not cut it just splice into it.
SOURCE: i need to find the
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
