Question about Vizio Televison & Video
Hookup vizio vsb207 soundbar to tv with xfinity cable.what is the wiring connection
Posted by Jack Bergstrom on
Marvin
    Top Expert:
  • Vizio Master
  • 85,239 Answers
You will need to hook the TV sound bar system to the Variable Audio output jack on the back of the TV.
Posted on Oct 26, 2016
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
Vizio sound bar won't turn on with tv
How to Fix the Vizio Soundbar ' Chron.com
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
Soundbar Won't Turn On ... Turn the volume up on the Vizio soundbar and also ensure the soundbar isn't muted. ... For example, even if the Vizio soundbar is connected properly, if the TV is set up to output through the internal speakers only, ...
Fix A Vizio Soundbar Remote In 4 Simple Steps ' Vizio TV ...
vizhdtv.com/fix-a-vizio-soundbar-remote-in-4-simple-steps/
Aug 25, 2015 - Each model of Vizio soundbar includes its own remote. It's what is ... Use the power button on the soundbar to turn it on. Then test ... So replacing thesoundbar won't resolve the issue if you have one of the effected models .
Nov 28, 2015 | Vizio Televison & Video
How to hook up a vizio soundbar model# vsb207
http://cdn.vizio.com/documents/downloads/accessories/VSB207/QSG_VSB207.pdf
Feb 19, 2015 | Vizio Audio Players & Recorders
Vizio help
Not sure the issue. HDMI from cable box to TV. Same with Vizio.
The soundbar usually connects to the optical out from the TV to the in on the soundbar. Subwoofer has to be paired to the soundbar. Instructions should explain or maybe find online by manufacturer
Aug 15, 2014 | Televison & Video
How do I hook up tivo,Vizio,Xfinity together?
You need a cable box from xfinity that does not have a DVR built in and then you need to see whether the Tivo can control it. You will need an ir blaster cable from here:
www.weaknees.com/tivo-cables.php
Then connect the Tivo to the cable box and the TiVo to the TV.
Nov 06, 2013 | Televison & Video
Where is the fuse in a vizio sound bar
It can be located at the main power supply section.
Apr 21, 2013 | Vizio Remote Control VSB207 Soundbar...
Televison & Video Logo
188 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
