Cell Phones Logo
Question about LG Cell Phones
My lg flip phone keeps speaking a women's voice every time any key is touched or the phone rings and loudly announces the number calling. How do you make it stop?
Posted by Steve McCready on
Marvin
    Top Expert:
  • LG Master
  • 85,242 Answers
Go into the tools and deselect it.
Posted on Oct 26, 2016
How do i change the message on my answering machine
Hold the announcement key down. If the old message is there it will read it out loud to you. If you wish to change it, just hold the announcement key and speak over the old message. Make sure you keep holding the announcement key as you record your new message. When you have finished recording, release the key. If you wish to hear your message push the announcement key again. Do not hold it down this time. If you are not satisfied with the new message, repeat the method by holding down the announcement key again and recording your message. Your old message will disappear once you have recorded your new one.
When I go into my voicemail and put in my password...TWO OF MY CONTACTS also appear on the screen under the password!!! I removed those contacts and then re-entered them into my phone and they reappeared...
Your new phone most likely does not have the bells and whistles to speak the name of the caller when you receive a call.
As for the names appearing when you call voicemail, those names could have similar numbers to your voicemail password. I hope this helps.
May 15, 2011 • Cell Phones
5helpful
2answers
I have a LG 220 C phone and I am trying to figure out how to deactivate the announcement feature on the phone. My phone is not ringing; it is just announcing the incoming caller's phone number.
Go into the menu. Then hit '8' (calendar, alrms, etc I think?). Press '1' (voice commands). You will then get a drop list to check or uncheck regarding 'deactivate', 'announce', 'announce +ring'. Select deactivate-- now your phone will ring normal! Son had same prob on his phone-- apparently he'd hit 'announce' at some point....
2answers
Had to reset the phone. on in-coming calls it used to say the persons name, where is that set-up
LG Xenon - for adjusting the audible caller announce feature: hit the options menu in the top right corner and select call alert, you can set the phone to announce the name or number of the person calling/texting before the ring.
keywords: call, caller, audible, announce, announcement, announcing, loud, alert, name, person
2helpful
SINCE NEW , UNABLE TO CHANGE RING TONE. IT ONLY
Under settings menu touch, more, applications, voice command, call alert. Change to ring only. Hope this helps.
1helpful
Phone is muted...No one can hear me when I am calling, or answering a call. I can hear them fine. Phone shows "muted"?? How do you "un" mute?
Receiving Calls
1. To answer a call, touch or open the slide.
 If the slide is closed, simply slide it up.
 If the slide is closed, press the Voice
Commands key twice, then touch .
 If the slide is open and the touch buttons are
lit, touch .
NOTE If you touch Left Soft Key [Quiet] while the
phone is ringing, the ringing or vibration is muted
for that call.
NOTE If you touch Right Soft Key [Ignore] while the
phone is ringing, the call will end.
Mute Function
The Mute Function prevents the transmission of
your voice to the caller. To quickly activate Mute
touch Left Soft Key [Mute], then to unmute
touch Left Soft Key [Unmute].
NOTE! while doing this you must call someone then while talking with him touch Left Soft Key [Unmute] to Unmute
Hope it help you out ^_^
try download the manual if you loose it
http://www.cellphones.ca/upload/manuals/lg-vx-8500-manual.pdf
2answers
No dial tone
This is the time that love cannot help with. Buy yourself a new home phone where the massages will pile up. erase all massages on your mobile phone. It is time to buy a cell phone which will record all masseges that you've received.
When calls come in, the name is announced. How do I reset to ring tone
Remove the voice dial information, or turn it off. Best of Luck.
Top LG Cell Phones Experts
David Shaub
George Etukudo
W.L.
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
