Question about GE Profile JGSP48 Gas Kitchen Range
Oven and Broiler are not Heating Up
I have a combination of the problems described for this model. Initially I had the two right hand stove burners that would not ignite so I decided to open up the cooktop to see if I could figure out the problem. I turned off the power and closed the gas valve on the attached regulator and proceeded to take the whole thing apart but did not find anything unusual. After putting everything back together lo and behold the front burner worked but the rear did not. Afterwards I stumbled across the post on fixya.com regarding the switches and was able to ignite the burner by activating another switch. Get a new switch mechanism, problem solved.
Unfortunately, I went to use the oven last night and it seemed to turn on (fan blowing) but never heated up. Same for the broiler. I reset the breakers with no luck and my wife is requesting I get someone in to help since Thanksgiving is 3 days away. Do you think I could have damaged the control panel? Could it be the ignitors? It would seem a coincidence that both failed. Is there any safety mechanisms that may be triggering if I didn't get everything back together?
I just thought of one other thing. When I shut off the regulator that is behind the bottom drawer I turned on one of the burners to empty the gas, however, it didn't seem to slow down. I believe I opened the valve again but it uses a little flip switch that did not provide much feedback if it is open or closed. Are there two regulators for the oven and stovetop and could I have been adjusting the oven and do not have the valve opened properly to provide gas to the oven?
Any thoughts would be appreciated.
Bill
Posted by wott on
  • kbear424 Nov 21, 2007
    Hello-
    I am having the same problem; however, I don't know where to find the flip switch is located. I have the JGS968 H3SS model.
    Thanks!
Gerald Griffin
  • 248 Answers
That flip switch is for oven. Turn on oven and wait about a minute, then flip switch. That should do it. Leave switch in this position.
It's easy to hit this switch.
Posted on Nov 19, 2007
3 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Our Electric Amana Self Clean Oven, the broiler is
canoyu physically inspect teh element for damage, perhaps its broken. or as wireleadingto the rearof elemnt has buntoff. you can check , but turn offpower first, the wires are always live
Posted on Mar 02, 2009
Anonymous
  • 9 Answers
SOURCE: Oven heats very slowly (Jenn-Air JGS9900BDS).
hi, Could be a bad bake element or a bad temperature sensor. If the element will glow bright red/orange with no hotspots it is OK. Take a volt/ohm meter set for ohms and check the temp sensor. If less than 1050 ohms replace it.
NephetZ
Posted on Jul 08, 2009
marka19
marka19
  • 1430 Answers
SOURCE: the oven will not light.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Jun 01, 2010
Indesit oven keeps heating
Tappan gas range, TGF334BCWB. I can NOT stop the broiler burner from lighting. I have unplugged the 110 power and I light top burner with a striker. However when stove is plugged in to the power the broiler burner lights and continues to burn. The oven knob is turned OFF. The only way to stop the broiler is to unplug the power.
Mar 11, 2014 | Whirlpool Accubake SF362LXTS Kitchen Range
I have a GE JGBP33CEH4CC GAS stove, The oven won't light, but the burners and broiler does.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 16, 2011 | GE JGBP33 Gas Kitchen Range
Top oven not heating up on BAKE, broiler gas and flames come on. Stove top burners work, Bottom oven heats for BAKE and BROIL.
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Oven burner does not light. broiler burner and all other stove burners are good.
heatman101
Nov 09, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Maytag Gas Range broiler burner not working
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Xl44 stove, the burners and broiler work but the oven won't turn on.
heatman101
Dec 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Bottom burner in my oven barely comes on, in turn, not heating my oven to the temperature that is selected. Top burner (or broiler seems to work fine). The gas stove is a GE XL44 and is 6 years old. Please...
You need a new t-stat control. Your element is fine. Give us a call with your complete model number and we'll get the right part out to you asap to get you ready for the winter.
Oct 18, 2009 | Ovens
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
GE Profile JGSP48 Gas Kitchen Range Logo
243 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Marvin
Marvin
Are you a Kitchen Range Expert? Answer questions, earn points and help others
