Pool & Spa Logo
Carol Griffith Posted on Oct 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The burner motor stopped working and I can no longer order parts for my heilsa QCPS 28000 pellet stove. Could it just be plugged and if not are there universal parts.
Brandon Todd
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Oct 25, 2016
Brandon Todd
Expert
Level 2:
New Friend:
Answers
51
Questions
0
Helped
14206
Points
148
If you are able to disassemble it get the motor out and clean and examine it. If it is a brushed motor Ace Hardware carries brushes for electric motors just take the motor with you to match the brushes. Use electronic components cleaner to clean the motor. It can be found at auto parts stores. Be sure to lubricate the bearings or bushings inside the motor while reassembling it
1helpful
2001 Warnock Hersey 25-PAF not working!
Even though it is 20 years old it is well supported by the company which is good to see! Problems with pellets stoves are pretty simple to fix, the most comon problem is the fire pot igniter, the auger motor or the fan. Diagnose though, don't just blindly replace items. It is well worth repairing and they fetch good prices secondhand. The links below you should help. The one has troubleshooting ideas.
25-PAF, 55-SHP25, 55-TRP25 - England's Stove Works, Inc.
https://heatredefined.com > collections > 25-paf-55-shp25...
25-PAF, 55-SHP25, 55-TRP25 ...
Englander 25-PAF Pellet Stove Repair & Replacement Parts
https://pellet-stove-parts-4less.com > collections > find-by-...
VistaFlame Ā· Vogelzang Ā· Warnock Hersey Ā· Waterford Ā· Generic Parts Ā· Grill Parts & Accessories. Grill Parts & Accessories.
England's Stove Works 25-PAF Owner's Manual ' Manualzz
https://manualzz.com > ... > Pellet stove > 25-PAF
Save these Instructions. Please Note the Following Precautionary Statements: WE DO NOT RECOMMEND PELLET UNITS AS YOUR ONLY SOURCE OF HEAT. England's Stove Works ...
Englander Pellet Furnace on CL Question - Firewood ...
https://firewoodhoardersclub.com > forums > threads
Jan. 30, 2014 - Warnock Hersey seriel # 000285 model # 25 paf. Don't pay new price only asking a $1000 or best offer, call Kevin. Location: Reynoldsburg.
1helpful
I have a Witfield Optima 3 and the lense in front of the flame sensor keeps getting smoke and soot build up causing it not to feed pellets and the stove goes out. What can I do?
I really don't know much about these things but a well designed stove would arrange for a portion of the draught to be channeled past the lens in what could be described as an air curtain in order to keep it relatively clear of smoke.
I expect your stove could use a thorough clean and it might be possible that some small but important component has been left out during past cleaning operations.
I suggest you obtain a parts list/exploded drawing and ensure everything is present and in good condition.
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 • Pool & Spa
Heilsa Pellet Stove Manufacturers Information
pellet stove tp440 Pool & Spa Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > pellet stove tp440
Pool & Spa Heaters pellet stove tp440 questions and answers. ... for a manual orinformation on this stove it is an older stove we just don't know how old. ... heilsa pellet stove model qcps-28000 my pellet stove is smoking how to change ...
General Infrared Sauna Heilsa Sauna Supplier, Find Best ...
www.alibaba.com/general-infrared-sauna-heilsa-sauna-suppliers.html
Suppliers who can match your search. .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter .... Infrared sauna room,Portable steam sauna,Infraredheater,Pellet stove,Clothes dryer ..... updates on topics such as trending hot products, buying requests and supplier information - sent directly to your email inbox!
Good Quality Far Infrared Sauna Supplier, Find Best Good ...
www.alibaba.com/good-quality-far-infrared-sauna-suppliers.html
Suppliers > .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter ...Infrared sauna room,Portable steam sauna,Infrared heater,Pellet stove,Clothes dryer ...compare heilsa infrared sauna with good infrared sauna accessories ..... buying requests and supplier information - sent directly to your email inbox!
Jan 06, 2016 • Pool & Spa
How do i fix ager on my pellet stove?
Hello Ethan, First I would uncouple and remove the auger motor from the auger shaft. Next turn the stove on to see if the auger motor turns. If it does turn, try to hold the motor shaft with your hand to determine if the motor has sufficient torque to turn the auger. If motor seems to be strong enough , use a pair of pliers or a vise grips and try to rotate the auger shaft. If the auger will not turn, it might be clogged up with pellets or pellet dust. The clog will have to be removed. If that is the case, I think the gears in the motor are stripped and a new motor is in order. Note: Damp pellets swell up and turn hard as concrete when they dry out.
Dec 06, 2013 • Home
We have a heilsa pellet stove model#QCPS-28000 ,its dropping pellets to fast ,how do I adjust the feed.
  1. SET THE AIR INLET DAMPERS
It is not possible for the manufacture to factory set your stove to work properly without some adjustments. The dampers help control the amount of airflow supplied for combustion.
A damper PUSHED IN all the way, maximizes concentrated air flow to the burn pot. This will maintain a robust fire.
The Auger timing is designed to be run, in most conditions, with the dampers closed.
In some areas/conditions, it mybe necessary to adjust the damper open slighty in order to slow down the flame and allow the pellets to keep pace with the rate of burn. This should be monitored closely to ensure you have the propoer feed rate established. If dampers are opened too much, the rate of burn will be very slow and the pellets will build up.
This setting needs to be fine tuned to according to your location and elevation. It is recommended that you start with the dampers pushed in to start.
3helpful
Heilsa pellet stove model qcps-28000
how to change control board on a heilsa pellet stove
Nov 27, 2011 • Pool & Spa
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
