Question about Motorola clp1010
I have a Motorola clp1010 and each time I press the button to talk it has a beeping sound. Is there a way for this not to happen?
John L radiodude365
    Master:
  • Motorola Master
  • 570 Answers
Yes. It is called a talk permit tone. It is on page 11 of your users manual. It seems to be suggested for Bluetooth headset wearers because radios are a one way communication device. It was unclear if you could re program this feature without using the software. The whole manual could use revamping on programming IMHO. Anyway www.motorolasolutions.com/CLP for manual. The software will have a link and it is free. You must buy the programming cable and I suggest buying Motorola's cable. You know theirs will work.
Posted on Nov 02, 2016
Can you stop motorola radio from beeping each time talk button is pushed
Nope...That beep lets you know that you can commence talking. If you start talking before you hear the beep, whoever you're talking to will not hear everything you say.
Sep 12, 2016 | Motorola Radio Communications
Why does my motorola talkabout turns off when I try to radio someone
That's what they call the roger beep It is there so that you wont say roger every time to signal the other side's turn to talk.
You can press MENU button, press once more until you can see the music(note) icon or the word 'Roger'. Select ON or OFF using UP/DOWN key. Press MENU to save.
Car Transimissions
Jun 12, 2012 | Motorola Talkabout® T9500 Two Way Radio
Why is there a beeping noise when I press talk?
When you press talk, there should only be 1 beep. This is to confirm that the Talk button has been pressed. If it beeps multiple times, this means the phone is not communicating with the main base station, or the battery is low or dead.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Apr 10, 2011 | Uniden Lands Phones
When I press the PTT button it will not beep after i talk
either that or take out the batterys and it will reset ist selft
Aug 08, 2009 | Motorola Walkie Talkie 2-Way Radio
How do you go to silent mode?
There are two different kinds of beeps you can control, the "roger" beep and the "button" beeps. Below is an excerpt from the owners manual explaining the simple procedure.
“Roger” Beeps/Talk Confirmation Tone
When you turn this feature On, your two-way radio transmits a unique tone when
you finish transmitting. It’s like saying “Roger” or “Over” and lets others know
you have finished talking. If the person you are talking to does not hear the talk
confirmation tone, you can enable it by pressing and holding + (plus) as you turn On
your radio. Now, whenever you release the PTT, you let your friends know you have
finished talking by transmitting a “Roger” Beep tone. “Roger” Beeps will be
disabled as the Default Setting.
Note: To toggle the Talk Confirmation Tone feature, turn your radio Off and then
back On while pressing and holding + (plus) .
Button Beeps
Every time you press a button on the front of your radio, it beeps unless you turn
Button Beeps Off. To turn Button Beeps Off, turn your radio On while you press - (minus) and
hold . To turn Button Beeps back On, turn the radio Off and then back On again
while you press and hold the - (minus) . On is the Default setting.
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T7100_User_Manual_E.pdf
17
Nov 28, 2008 | Motorola T7100 2-Way Radio
Shutting the beep sound off when you turn on talkabout T7150
Button Beeps
Button Beeps Off. To turn Button Beeps Off, turn your radio On while you press and
hold the minus (-). To turn Button Beeps back On, turn the radio Off and then back On again
while you press and hold the minus (-) . On is the Default setting.
http://www.motorola.com/mdirect/manuals/T7100_UserGuide.pdf
Nov 15, 2008 | Motorola Talkabout T7150 Two Pack 2-Way...
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 25, 2007 | Motorola TalkAbout T5530 2-Way Radio
Motorola Talkabout T5100
I think you have to remove the courtesy beep option from radio, this is also call Roger beep.
Dec 11, 2006 | Motorola Talkabout T5100 (14 Channels)...
Motorola clp1010 Logo
983 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
