Brother LS-1217 Mechanical Sewing Machine Logo
s
susan haney Posted on Oct 22, 2016
How to get front cover off - Brother LS-1217 Mechanical Sewing Machine
How do I remove soft touch button pad on Husqvarna Platinum Plus sewing machine?
https://manualmachine.com/husqvarna/platinum-plus/919500-user-manual/
Stitches won't work on Bernina 1080. Sometimes the reverese button works, sometimes it doesn't. Specialty stitches don't appear the way they are supposed to. Everything was fine a couple days ago.
This problem will be found in the computer PCB. You can remove this by:
  1. Remove the handwheel, end cover, and protective cable shroud.
  2. Disconnect the cable plugs from the circuit.
  3. Slide out the entire front cover with attached circuits. NOTE: Do not handle the circuit boards with your fingers except on the front cover edges.
  4. Slide the entire front cover with attached circuits in a PCB static bag and send to: NIT, Inc, 127 Peachtree Dr, Centerville Utah.
They will repair this circuit for you quickly.
My dog knocked a wood burner into the front cover of a fashion mate 69 stitch computerized machine is there a way to replace the front cover?
Probably. However, the first issue is finding a replacement cover--may have to find a used donor part for that. Second issue is actually getting the old cover off and the new cover on without cracking or breaking anything, ie the plastic clips that hold the cover in place.
2answers
How to Remove front cover of Brother CS-80 sewing machine
Have you tried Alans Alterations at the MID WALES SEWING CENTRE they have a huge presence on ebay.They should be able to help you,or point you in the right direction.
Removing the covers on a viking 980
I assume you're talking about the main back and front cover. Unless you really are skilled, I'd leave this project to a professional.
I've worked on the Designer I, II type machine and I believe yours has similar construction. You need screwdriver bits with a 6 pointed "star" head. Screws in the cover itself are "H10" size. Screws in the base are "H15" size. The back cover has to be taken off first before you can get at screws for the front cover. Typically there are 5 screws on the back cover that have to be removed and 2 in the bottom of the base. Note that the front and back covers "snap" together and have to be unsnapped after the screws are removed. If you have to take off the front cover (requires removing more screws in the cover and base), be careful with the various wiring harnesses that attach to the main circuit board.
No front cover test mode
Well, you certainly wouldn't ask a sewing person for help. lol
Try re posting your question in faxes and or printers.
11helpful
How can I get the case of my Singer Featherweight II open?
To remove the cover of the Singer model 117 Featherweight II sewing machine:
Referring to the diagram below:
1.Remove the face plate by removing the single screw fastening it to the left end of the chassis.
2.
To make things easier, remove the presser foot (raise the presser foot and release the presser foot from its holder by pressing the black plastic foot release found at the rear of the foot holder, the foot will fall off.)
3.Remove the plastic see-thru slide plate that covers the bobbin. Remove the bobbin, and remove the two screws that secure the needle plate.Lift off the needle plate.Don't mess with the feed dog screws( Look closely at the" bobbin case assembly" and note how it is installed. The black thing you are looking at is the assembly. The chrome thing that looks like a hook is a fixed "bobbin case stop plate" , the case assembly fits under that and is supported by the hook race. Approximately 180 degrees from the fixed stop is a spring stop- note that the bobbin case assembly is free to rotate/ wiggle approximately 1/8" between these two points, and it is seated evenly in the hook race.Remember what you see so you can reinstall it later)Remove the bobbin case assembly with your fingers.
4.Remove the detachable tool case from the front of the machine by sliding it to the left.
5.The face cover is fastened to the chassis with four screws- two on the bottom which also pass through the bottom of the rear cover, one behind the face plate just above the lower thread guide, and one on the front of the machine behind the tool case. Remove the screws on the front and the left end, and loosen the two screws on the bottom ( if you are planning to remove the rear cover go ahead and remove the bottom screws completely.) There is no need to remove the screws that hold the auxiliary leg bar.
6.The screws are out- HOW DO I GET THE COVER OFF!?!
There is a hidden locking tab located just beneath the mylar seal that warns you to disconnect the machine before servicing and to close the cover before operating the machine. It is located just to the right of the needle plate and directly over the seam that separates the front and back covers. Don't remove the seal just slice it with a razor blade or utility knife right along the seam, make sure you cut all the way through the seal.
Working from the needle plate opening, take a medium sized flat-bladed screw driver and slide it under the rear cover just behind the seam (see photo) carefully twist the blade in a manner that both separates and lifts the rear cover off the front cover- it takes quite a bit of force and it will let loose with a loud snap. After the locking tab is loose the front cover is easily separated and lifted off the chassis.
unlocking the case:
a closeup of the tab on the front cover
7.The rear cover is held on by three screws. There is one through the back at the handle recess, and there are two screws accessible from the front after the front cover is removed. Lower the presser foot lever, pull the screws and the rear cover will come off easy. Good luck with your repairs.
1helpful
Remove Cover
Sorry for asking which machine you are opening. I got to this post through multiple links and didn't realize I was in a Designer 1 area.
Yes, you do need to remove screws in the bottom to remove the covers. I do not recommend that you do this due to electrical safety issues. When the front cover is lifted away from the machine, you will find 6 different types of connectors attaching cables between the front cover and the machine. You will be able to move the front cover approximately 3.5 inches away from the machine to reach in and disconnect these cables. The touch screen cable, if it has not been replaced, is very short and very fragile and will cause the touch screen to stop working in the blink of an eye. If you don't know what you are doing, it is dangerous for both you and the machine.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
