Tablets & eReaders Logo
Diane jones Posted on Oct 22, 2016
Curtis tablet lt8088 powers on but wont reboot back to factory cause I cant use tablet
My son set a privacy password and now cant remember it. how do i get in to reset password?
There is no way to recover a lost password without erasing the device.
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button.
Go to the option for Factory Data Reset and select it. Scroll down to Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
1helpful
2answers
My nabi dreamtab wont reset why?
There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset: Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabiâ„¢ Sync.
I have a klu by Curtis LT -1041-c screen went black can't get it to come back on.help tablet.
1. Make sure tablet is off.
2. Press and hold the "Volume Down" key and 'Power' key
3. When "Klu by Curtis" splash screen shows release the power key
4. A laying down android with cover open and a red triangle with an exclamation point will appear.
5. Rock the 'Volume Down' and 'Volume Up' and press the 'Power' keys to dislplay the BIOS screen.
6. Use the 'Volume Up/Down' keys to navigate choices (wipe data/factory reset) and the 'Power' key to select the choice.
7. The following screen will ask you to confirm your choice and warn you that this cannot be undone. Repeate step 6 to select your choice.
8. When wiping all data is complete, select 'reboot system now' to restart tablet.
Done!
How do i fix my tmax tablet that wont reboot
if you can shutdown it.
boot in recovery mode and use this command ( wipe data / factory reset ) and ( wipe cache partition )
Tesoar tablet freezing on tesoar screen
Try this:
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
5helpful
2answers
I have a craig touch screen tablet and i forgot my dot password how do i reset it?
Power the unit off (holding power buttom) and selecting Power off, then hold simultaneusly back button and on buttom 8 seconds,the android icon appear press back buttom, in the menu select wipe data/factory reset pressin home buttom and then press back buttom, in the next screen select "yes delete all user data" pressig back buttom, and in the nex screen select "reboot system now" with the back buttom and wait. IT WORK FOR MY TABLET
2helpful
Wont reboot like standard reboots
If the iPad will not reboot using the standard "Hard Reboot" (holding the power button and home button until the iPad restarts.) then I would advise restoring the iPad using iTunes which will set it back to factory settings.
Top Curtis Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Curtis Tablet and eReader Expert? Answer questions, earn points and help others
