Question about Sony Playstation 3 (PS3) Console
My ps3 cech3004b when I on it shows green stays for 7secs then goes off till I press the power key again it goes to standby, the fan spins but nothing show on TV any help please.
Posted by Emmanuel Frank on
  • Emmanuel Frank Oct 24, 2016
    thanks a lot but which reballing station will u advice me to buy I want to do it my self I just want to give it a shot and what equipment are needed for reballing
5 Related Answers
Anonymous
  • 709 Answers
SOURCE: PS2 slim Power Problem - Light is red goes green but nothing else.
Hi Leostg,
I have seen this a couple of times.  Lightning or an overload has burned up the motherboard. Its not a fuse, its a fried Emotion Engine processor.   Best advice on dead motherboard is to probably total it unless you can get a low price motherboard replacement. My cost on a new motherboard for slim is about $55.  If you want it fixed, replace the motherboard.  Really you may be able to get another Slim for $55 or less. If you look on ebay  for another motherboard do not take any chances on used motherboards. Go for a broken slim model that will boot up but want read discs. When you get one that boots up, use its motherboard in your Slim.  This will be your best deal at getting your slim up and running once more.
Please give me a Solved vote. I believe you only get one vote and its locked.   I have put a lot into your solution and hope you will show appreciation by voting solved.
Posted on Oct 17, 2007
Anonymous
  • 7 Answers
SOURCE: nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Posted on Mar 20, 2009
Anonymous
  • 5 Answers
SOURCE: XBOX 360 power brick flashing orange and green
according to the microsoft website:
The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply itself. The power supply can turn itself off when there is too much current, too much voltage, or too high a temperature. Under these conditions, the light on the power supply will turn from green to orange or to red. Or, the light will turn off. When the power supply light is green, the power supply is working correctly.
To help the power supply work correctly, always try to use the following best practices:
  • Make sure that all ventilation openings in the power supply are free to ventilate.
  • Do not put the power supply on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
  • Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
  • Plug the power supply directly into a wall outlet. In other words, do not use extension cords or power strips.
Basically, feel if it is overheated. if it is let it cool down. If not try a different wall socket. If that doesn't work you probably have a problem with your power brick or console. Try borrowing someone else's power cords.
Posted on Jun 15, 2009
SOURCE: my ps3 shows nothing but background waves, wont load main page
unplug PS3. Wait 10 minutes and turn on.
do the same with the power supply.
Posted on Aug 31, 2009
Anonymous
  • 12 Answers
SOURCE: when i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Posted on Dec 06, 2009
Blank screen, not reading dsc
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
When I turn on my PS3, the sony music begins and the orange sony wave screen turns on but it doesn't move on to the menu. I have shut the system af by turning off the button at the back of the PS3, I have...
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
My 60GB PS3 is having trouble starting up. Some red and green spots show up and then freezes. It took some pictures when it freezes. Any help? Is my PS3 going to need service? Is it just a HDD issue? Many...
THE GREEN LIGHT COME ON THEN IT CUT OFF
Oct 24, 2009 | Sony Playstation 3 (PS3) Console
My ps3 froze and now doesnt show anything on the screen and controller doesnt turn it on. nothing happens
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
My PS3 has no menu. No sound or video
try video reset
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
Hi- we are having a problem with our ps3....it just started overheating....we forgot to open the door...I heard the fan kick in...so we turned off the ps3 to let it cool down....now the ps3 is running...we...
try video reset
My ps3 stopped showing picture ,it was working i turned it on i saw user screen then nothing,already replaced video cord
try video reset
My ps3 has a fuzzy screen when playing on it this only happened a few days ago should i tae it back as it is only 4 weeks
first try video reset
then take it back as these steps will not void warrenty
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
WHEN YOU TURN ON THE PS3 AND GETS TO THE USERS IT DOSENT DO ANYTHING AND DOSENT SHOW THE USERS
Oct 17, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Daniel Dollive
Daniel Dollive
Steven Wander
Steven Wander
Raj Patel
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
