Re: 1957 Evinrude Fastwin 18. Converting to a fuel pump....
Use any good quality low pressure fuel pump (5-7 PSI) that is of good quality. Use a relay to activate the pump. You can buy the pumps cheap from www.summitracing.com
I'm not entirely familiar with that model off the top of my head. However, the flywheel for that model seems to be 0583001 which is a 74 tooth. With that said, I make no promise but https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1988&hp=20&model=E20CRCCA&manufacturer=Evinrude§ion=Electric+Starter+%26amp%3B+Solenoid matches that flywheel. Hope that helps some, maybe guides you in the right direction.
Sorry that link didn't go through as I had planned. The starter drive assembly for the 74 tooth is 321648 — DRIVE ASSY., 11 TOOTH. USE ONLY WITH FLYWHEEL P/N 583001 (74 TOOTH). The starter shows to be 5376 - Outboard Starter, Johnson Evinrude, 18-40HP
3014 is a three horse 1955 Evinrude Lightwin. 16/1 fuel oil mix, points set at 0.020 and the NGK B6S plugs set at 0.030". 80-90W marine grade gear oil is used in the gearcase. Nice motors!
No,check vro fuel pump diaphragm.if primer bulb doesn't get hard when priming is a sign of needle and seat not sealing or a hole in fuel pump diaphragm.
