Question about Motorola Televison & Video
Program FiOS remote STB button as ''master'' control for all
Received a replacement FiOS remote & programmed it for the TV, receiver & DVD. I have to push each button individually to power on & off & have to push the aux to control my volume. I know there is a way to program the STB button to be the ''master'' control for all components, but I forgot how & it's not in the instructions. Please help!
Posted by jokmalta on
5 Related Answers
Anonymous
  • 163 Answers
SOURCE: no code for expressvu
try the 7771 if not sorry but thats your last chance...good luck
Posted on Aug 07, 2006
Anonymous
  • 102 Answers
SOURCE: Programming (JR800C) universal 8 Jenson remote controller
Google for the Jenson website, the chances are you will be able to download the manual for this remote.
Posted on Oct 06, 2007
Anonymous
SOURCE: program for my tv
Push the t.v. button on the remote then push and hold the on/off button and the t.v. button down at the same time until the on/off button comes back on and stays on, then you release them both. Then push the CH+ or channel up button on the remote and the on/off button alternatively until the t.v. goes off or comes on, each time you hit the CH+ button on the remote you are advancing the code for you t.v. forward in your remote, after your t.v. comes on or off then hit the stop button on the bottom of the remote and you have stored the code for your t.v. Hope this helps.
Posted on Oct 21, 2007
Anonymous
SOURCE: direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Posted on Jul 29, 2008
Anonymous
SOURCE: Need code to operate Dynex Flatscreen TV on Verizon Fios
The code is 0490
Posted on Aug 03, 2008
How to get volume control on my FIOS remote with Samsung TV?
Re: How can I get the volume control on my FiOS remote to change the volume on my AV receiver?
  1. Hold down the STB button on your remote control, and press OK. Release both buttons.
  2. Key in 9-5-5.
  3. Press the device button whose volume you want to control by default (in this case, AUX).
  4. Press OK.
https://forums.verizon.com/t5/Fios-TV-Technical-Assistance/How-can-I-get-the-volume-control-on-my-FiOS-remote-to-change-the/td-p/246987
5helpful
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
2helpful
Having problem to use the Verizon FIOS Remote control to control the volume of my Sceptre X42 LCD TV. The FIOS remote is able to turn On/Off the TV though. Any idea what is wrong with this?
program the remote to control tv volume by 1. Press and hold the STB key. 2. While holding down the STB key, press OK. 3. Release both keys. The Device Keys will blink twice. 4. Press 9 - 5 - 5. The STB key will blink twice. 5. Press TV. The TV key will blink 3 times to indicate success in programming. try the remote after that . if the volume still doesn't work check to see if there is another code that also works with your TV. (on my Sony TV one code works everything while another code only turns it on and off. for my Epson S3 the remote will not work with it at all.) here is the manual for the remote: http://www22.verizon.com/NROneRetail/NR/rdonlyres/2DEF67C9-87F0-4B46-B1BD-A40472BC281A/0/PhilipsRC144RemoteControlUserGuide.pdf
JUST BOUGHT AN OPEN BOX TOSHIBA T.V. MODEL #26LV61OU LCD-HD AND IT DIDN'T HAVE A REMOTE. IT'S WORKING WITH MY VERIZON FIOS BUT I CAN'T CONTROL THE SOUND. WHAT TYPE OF REMOTE SHOULD I GET FOR THIS T.V. AND...
The remote that came with your Verizon FIOS can be programmed to control the sound on your TV. There are four different remotes can come with Verizon FIOS, and there are three different procedures to program them. I will give you all three to print out try to fix your remote control problem.
Does your remote look like either of these two?
If so you have a Philips universal remote. Here are the steps to find the code that will control the sound on your TV:
1) Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
2) Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons. The mode buttons blink twice.
3) Press 922.
4) Point the remote control toward the device you are setting up and press the upper part of the Play button.
5) Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
6) When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
Note:
There are over 200 possible combinations for TV and DVD codes. The most common codes are tried first but you may still need to press the Fast Forward or Rewind buttons over 200 times to find the correct code for your device.
If you reach the end of the list of codes, the entire remote flashes twice and returns to normal operation. You can exit programming at any time by pressing the Exit button.
Does your remote look like this?
If so, your have a Motorola universal remote. These are the steps to find the correct code to control your tv:
  1. Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
  2. Note: The DVD/VCR button can control a DVD, VCR, or a combination TV/DVD, TV/VCR, or TV/DVD/VCR.
  3. Press and hold for six seconds the device button for the device you turned on in step 1 (AUDIO, DVD/VCR, TV, CABLE).
  4. The lights for each device button light up and the light for the device button you selected remains on.
  5. Press the Power button on your remote.
  6. The device button blinks three times then turns off.
  7. Press the Up arrow button (this is the button directly above the OK button, not the Page Up button).
  8. Did the device turn off?
    Yes: Congratulations! You've found the correct code for that device. Press OK to store the code in your remote control.
    No: Repeat step 3 and 4 until your device turns off, then press OK to store the code in the remote control.
    Note: To retry the previous code, press the Down arrow button (not the Page Down Arrow button).
If so, you have a Scientific-Atlanta universal remote. Here is how to find the control codes for your TV:
  2. Press and hold the Select button while also pressing the device button for the device you turned on in step 1 (AUX, DVD, VCR, TV, CBL) until the device button blinks twice.
  3. Press 991.
  4. The mode button blinks twice.
  5. Point the remote control toward the device you are setting up and press the Play button.
  6. The remote control tests each code in its library. The mode button blinks once each time the remote transmits a new code. When the last code is reached, the mode button blinks twice.
  7. When the device powers off, press the Select button.
  8. Verify the new code is correct by pressing the Power button.
    Did the device power on again?
    Yes: Press Select to assign the code in your remote control.
    No: Turn the device on and press the Channel Up or Channel Down button to step forward or back to the correct code. When the device turns off, press Select to assign the code.
___________
One of those three should work for you.
Hope that helps.
I own a Go-Video DVD-VCR Player, Model DV3140. I recently switched to Verizon service and find that I can no longer olay my DVDs/VCRs with the Fios System. Can you assist me in how to program my player...
Hi
You can reprogram it by following these instructions--
Power turns on or off both your STB and TV when you are in STB mode. (If you have a DVR STB, the DVR will continue to record scheduled programs when off.) However, you can reprogram how the Power Key works. If you want the Power Key to control multiple devices at once --
4. Press 9 - 7 - 7. The STB key will blink twice.
5. One after the other, press each Device Key you want the Power Key to control, in the order you want them to turn on or off. Each selected device Key will blink twice after it is pressed.
6. Press OK when done. The STB key will blink three times to indicate success in programming.
For example, to program the Power Key to turn on or off your TV, AUX and
STB, in that order with one press of the Power Key, press [STB+OK], [9-7-7],
[TV], [AUX], [STB], [OK].
These are the codes for GO Video DVD Player--
Go Video 0771, 0768, 0810, 0896, 1071, 1102, 1185, 1757
You can view/download the manual for the fios from this link--
Verizon fios remote programming
You can visit this link for more information--
Verizon FiOS Troubleshooting
If you want to doanload the user manual for your verizon set top box you can get it from here
Please do accept this solution and revert for further assistance.
Thanks
Rylee
4helpful
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
1helpful
Fios code for Winbook TV
If you do not know the device codes for a device, or if you've tried all the listed device codes for your device and none of them work, you can search for the correct device code by following the steps below.
Note: These steps only apply to the Philips RC 144 Remote Control. If this is not the make and model of your remote, go to the supported remote control models page and find the instructions for your specific remote control.
Searching for a Device Code
  2. Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons.
  3. Press 922.
  4. Point the remote control toward the device you are setting up and press the upper part of thePlay button.
  5. Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
  6. When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
  7. Note:
1helpful
FiOS TV remote control
bought an new one for $5.
1helpful
2answers
Remote code for PV-M1349
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
17helpful
10answers
Code for Verizon FIOS remote Control
I have a solution which has worked well for me. It uses the DVD button at the top of the remote. It was a trade-off as none of the codes in the RC144 Philips remote will work any Blu-ray players, so the DVD button was unassigned. The 922, 955 and 977 codes are explained in the directions for the FIOS remote. http://onlinehelp.verizon.net/consumer/bin/pdf/philips%20rc1445302%20user%20guide.pdf
1. Set up your TV button to work your TV.
2. Set up your Onkyo code, pick one to turn on the receiver. I used 3719
3. Use the 9-2-2 code to cycle through all available codes. At about a count of 300 I found one which will turn the Onkyo receiver off. Make sure you start this process with the ONKYO receiver already on. Once you find it press the OK button.
4. Use the 9-7-7 code to power all devices TV, AUX and DVD from the power button.
In this way, each time the power button is pressed it will send both the power on and power off signal to the ONKYO receiver.
This technique works well when you point the remote at the ONKYO receiver and press power button. Apparently the TV has better reception for the signal then the ONKYO does.
Televison & Video Logo
Top Motorola Televison & Video Experts
Joaquim Martins
ray gallant
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
