Error code #E70
Hi
Error code E70 means Cold water hose is connected to wrong faucet or Cold water faucet is not turned on. If this is not the case then check the cold water hose, whether it is kinked or plugged. If the hose is fine then the fill valve assembly has turned bad and you would need to replace the valve. Connect hose to cold water faucet and cold water inlet on washer. Be sure cold water faucet is fully opened.Hope this helps... Please post back for more information.
Daniel
Hi Ron Corkrey, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
