Question about Samsung Cameras
How do i know the maximum memory capacity of samsung p30
Tony Parsons
  • Samsung Master
  • 6,308 Answers
Google it
Posted on Oct 21, 2016
What is d maximum capacity for message storage?plz reply soon i wanna purchase it...does it has unlimited storage capacity
Hello and Welcome
There is no maximum capacity of messages in Samsung S3650 Corby, The maximum capacity of messages in Samsung S3650 Corby is 500 messages
For further assistance, I am here to help.
Thanks and Keep using FixYa
Mar 18, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Samsung P30 PC Notebook what is the Cache memory
The cache memory is dependant on the CPU that is installed, but it is usually 2 megabytes.
Jan 20, 2011 | Samsung P30 Notebook
Memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
Apr 29, 2010 | Samsung Digimax D73 Digital Camera
Samsung P30 laptop memory upgrade -- how to
At the back of your laptop after you turning upside down then gently unscrew the screw that is holding a small path covered then loose the screw and you find them in their slot ok gently pull the two metal clip side ward and it flip out then replace it ok
Mar 11, 2010 | Samsung P30 Notebook
Can I use a 4GM SDHC card in my Samsung Digimax S800? The manual says "up to 1GB guarantied".
No. Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Oct 16, 2009 | SanDisk 4GB microSDHC Memory Card
What is the maximum memory capacity of acer aspire 5600 model
According to the specs of this laptop model, it supports up to 4 GB of DDR2 533/667 MHz memory using two soDIMM modules. This means that you will have to replace the 512 MB memory module already installed in your laptop, & replace it with 2 soDIMM DDR2 533/667 MHz memory modules, each of 2 GB capacity.
Jul 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Trying to price/find ram upgrade for compaq presario m2000
You can go to the manufacturer website and check on the product model specifications to show you the correct limits. For example, if you have a hp laptop, go to www.hp.com and enter your product model in the search. then look for product specification page and you should be able to verify the memory limits
Mar 10, 2009 | Computers & Internet
Cameras Logo
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
