Question about Plumbing
Do I have to disconnect the water hoses under the sink when I turn the neck counter-clockwise? I am on my 2nd replacement faucet.
Same faucet as in picture, Fairbury by American Standard.
Posted by John Nyitrai on
johnny bonacci
    Sergeant:
  • 258 Answers
You do not have to disconnect the water hoses, but you do have to turn the water valves off before loosening any parts on the faucet.
Posted on Oct 20, 2016
  • John Nyitrai
    John Nyitrai Oct 23, 2016
    Thank you Johnny, worked like a champ and was fixed in less than 10 minutes. Great advice!!
  • johnny bonacci
    johnny bonacci Oct 23, 2016
    Glad to be of some help for ya.
Installing kitchen sink
Shut off water to both hot and cold water lines under sink. Place a bucket under water lines then disconnect them from under side of faucet. Disconnect drain and p-trap under sink. Disconnect sink hold-down brackets under sink where they connect to counter. Use a sharp thin knife (utility knife) to separate sink caulking from counter. Lift sink free from counter. Disconnect faucet from sink. Reverse these steps to install new sink.
Sep 26, 2018 | Home
How do I put my pull out faucet back?
Under the counter there is a weight on the hose. If it gets stuck on something you placed in the cabinet under the counter then the weight can't help you put the faucet head back in the fixture. Check the cabinet under so that the hose and weight are free.
Sep 30, 2014 | In-Sink-Erator Insinkerator HVIEWC-SS...
Got cold water in cold water tap but no water in hot water tap,why?
Did you check the turn valve under the sink. It's kind of similar to a water hose spigot on the outside of a house. If it's off you'll have to turn it counter clockwise to allow for water to flow to the faucet head. Also check the pipes by the hot water heater and make sure the valve is opened. Just follow the pipes coming in and out of the heater to find them.
May 21, 2014 | Vehicle Parts & Accessories
Turned on hot water faucet and i can't turn it off. I can rotate the faucet knob back and forth but the water won't turn off. Is the valve stuck open because of too much pressure or something...
With no model number, I will assume that you have a two handle faucett assembly, although they are both about the same. Either the knob and/or srew is stripped in thr stem of the knob. Hopefully the screw is just loose. If this is a sink faucet, you should be able to turn the water off to the faucet in your vanity under the sink. If it's a shower faucet, you will probably have to turn water off to the whole house. Any way, you may be able to get away without having to do this now but, I'd find out where the shut off is nad be ready. You should be able to remove the center part of the knob by getting under it with a small screw driver or butter knife. You should see a screw taht hold the knob on. Hopefully you can get this screw out or, by trying to grt it out, turning counter clockwise, you will turn your water off. If you can't get the screw out, you will have to drill it out, remove the handle, and turn the stem counter clockwise to turn off your water. In ant rate, you will orbably have to replace the valve, unless it was just a loose screw.
Jun 17, 2011 | Home
Water leaking under handle
This faucet has two O rings under the handle..Turn the water off at the valves under the sink, there is an allen wrench screw at the back of the handle. Loosen the allen screw, take the handle off. Then you will have to unscrew the faucet head from the base. (counter clockwise). Once the head is off you should see two O rings you will have to change them both. Also, inspect the O ring on the head itself. You should go ahead and change them all. Hope this works for you.
May 13, 2011 | Kohler K-10416-BN Fort½ Single Control...
It sprays fine but off the spray thair is no presuser . we replaced the water lines in the house we have good preasure though out our home jest not at the kitchen sink
One of the greatest things about Franke Faucets is that they have a lifetime guarantee. If you recently changed the waterlines in the home then more than likely when the water was turned back on or lines pressurized the settlement in the water main (Outside of your home) was activated and clogged the aerator. Most aerators simply turn counter clockwise (With the water off) after remooving the aerator simply clean and dislodge any particles in another sink. As for the pull out, some models have an inline screen located between the hose and the faucet handle. Simpy remove the handheld faucet (With the water off) and clean the screen.
Feb 02, 2011 | Franke FF-303 Kitchen Faucet with...
My delta signature faucet is leaking from the top of the hose. I want to take the hose out to get a replacement. I have started to disassemble the faucet but don't know how to remove the cap.
i am not sure which cap you refer to. there is a cap just below the handle. turn off the water supply for safety and remove handle then turn the cap counter clockwise. to replace the hose you should only have to disconnect at the handle to the sprayer and the other end at the faucet below the sink. if you wish to remove the faucet then after shutting off the water undo the nut below holding the faucet in place. delta have a good web site where you can see a breakdown of this faucet.
Dec 29, 2010 | Delta Model 470: Signature Kitchen...
Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
May 22, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
I have a leaky faucet in my bathroom sink it does not have the screws thats why cant open it
YES YOU CAN, JUST HAVE A LITTLE FAITH. THIS TWO HANDLE FAUCET ACTUALLY HIDES THE SCREWS UNDER THE HANDLE. SIMPLY TWIST THE HORIZONTAL SHAFT OF THE HANDLE COUNTER-CLOCKWISE AND IT WILL REVEAL A SET SCREW WHICH WILL ALLOW YOU TO REMOVE THE HANDLE FROM THE BODY OF THE FAUCET. REMEMBER TURN OFF THE WATER.
Nov 23, 2009 | Delta Victorian 2155-SSLHP Bar Two Handle...
How do I disassmble a jado kitchen faucet with
you have to locate the water shut off valves before you attempt removing the water lines, hopefully they will be located on the lines under your sink, if not you will have to shut the water main off coming into the house. After you have shut the water off and disconnected the lines, look under your sink at the back were your faucet comes through the sink and you will find the fasteners, unscrew these counter clockwise and the faucet will lift out .
Sep 03, 2009 | Jado 827-850-144 Shogun Single Lever...
Plumbing Logo
179 people viewed this question
Top Plumbing Experts
Bill Johnson
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
