Televison & Video Logo
Ashley Alsup Posted on Oct 18, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The directv screensaver came on the SYFY channel (only the SYFY channel) amd I can't make it go away
Steve
Level 3:
  • Directv Master 3,290 Answers
  • Posted on Oct 25, 2016
Steve
Directv Master
Level 3:
Answers
3290
Questions
Helped
1127876
Points
12184
Most DTV related problems can be repaired by a RBR (red button reset). Locate it behind the access card door. Press for 2 - 3 seconds and release. It will take about 5 - 7 minutes for the receiver to reboot. If you cant find the RBR button, remove or unplug power from the receiver for a few seconds and plug back in. If the screen saver still shows - call DTV.
2answers
I am streaming ATT Directv Now with my ROKU on 1 TV with no problem; however, I can't find it on my other ROKU device even when doing a channel search. What am I not doing right?
If you are trying to watch and activate DIRECTV NOW channel on your device then get these instructions to add DIRECTV NOW on your Roku device:
1. If you are using Roku device, then you need to install Directv Now channel on Roku player.
2. Then visit Roku Home screen from your Roku remote.
3. Now, go to your Roku channel store and start finding DIRECTV NOW from the channels list.
4. If you successfully find the DIRECTV NOW Roku channel, just select the channel.
5. From the DIRECTV NOW channel screen, you need to click on "Activate or add channel" option.
Finished, you have added the DIRECTV NOW to your Roku account. You can enjoy on your Roku player; Live TV, Unlimited Movies, On-demand videos and Sports etc. To get more information about DIRECTV NOW channel and other Rou channels then you can contact here now https://rokucomlinkhelp.com/
Recordering with directv
You can record either the channel 3 or channel 4 output channel from the DirecTV box or connect the analog audio and video outputs to the recorder's inputs and use the In1 or In2 inputs.
Some channels on direct tv have a black rectangle
Either your tv or your directv receiver is on the text mode of the closed captioning function turn closed caption off and this will disappear.
2helpful
I tried to program my remote control to power my sharp tv and it will now turn the tv on and off but I cannot get any directv channels and the screen is fuzzy.
PUT THE DIRECTV REMOTE BACK INTO THE TV MODE TURN THE TV TO CHANNEL 4 OR 4 THEN PUT REMOTE ON DIRECTV TO CHANGE CHANNEL ENJOY
2answers
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
Recording 3 digit channels
With the VCR connected to DirecTV, you're not picking the channel with the VCR anymore. You're picking the channel on the DirecTV receiver, and the VCR will record on channel 3 or 4 (if you've hooked the receiver up using the RF output to the VCR) or through its line (A/V) inputs if you're using those. The tuning range of the VCR is completely unimportant.
With your new system, though, there's one big drawback. Since the VCR is always set for channel 3 or 4, or its line input, and you're changing channels on the DirecTV receiver, you can't program the VCR to record several different channels if you go out. You won't be home to change channels on the receiver, so the only channel you'll be able to record is whichever one you've selected before you go out. Remember the VCR is taping the output of the satellite receiver, and not the satellite channel directly. If you record on some channel other than the receiver's output channel, there won't be anything there. All you'll get is snow or a blank screen.
1helpful
How do I hook up a daewood vcr to a TV through a Direct TV
If you are trying to connect a VCR to your television and still have Directv, this is the way to do it. Disconnect your Directv receiver from your television, Then connect the VCR to the television either through coax or RCA cables. If using the coax cable connect the out to tv on the VCR to the television. If using RCA cables connect the RCA OUT to the television AV1 connection. Once that is done, connect tha Directv receiver to the VCR using either coax or RCA cables. the Directv receiver only has RCA outputs so, if using RCA cables connect to VCR in. Remember that in order to see the Directv the VCR needs to remain on and it must be on the channel line in. If using coax cable connect to the VCR where it says in from antenna. Remember that if using this method your VRC does not have th remain on to view Direct. If you're trying to record Directv, then your VCR need to be on the same channel as the Directv output channel either channel 3 or 4. If trying to record Directv using RCA connections the VCR needs to be on the AV settings. If you have any futher questions please feel free to call me at (361)510-0339
Jonas Lopez
Jag Satellites/ Directv
Installer and Technician specilist
[email protected]
How to hook my directv to digital input to lcd tv j32l637
I don't know what flat screen tv you have,but you must be aware of the coaxial input behind the TV.It could be analog input,digital input and OUTPUT!!
Anyway,if you connect your basic directv box to your digital input,it will not serve you any purpose to get HD channels and you don't have the HD directv box.The TV will not display digital channel for you because if you use coaxial input to TV,you should be under either channel 3 or 4 and be sure either channel had been saved under memory.In order to change channels,you will need to change it from your directv box.
JUST LIKE a VCR connect to TV.TV will be under channel 3 or 4,and you will change your channels from the VCR.Don't forget to scan all the channels from the VCR!
solutiondoct
1helpful
Sammsung s4253 plasma tv audio garbled on digital channels
I had the same problem with my S4253 using Directv. I then turned off the Dolby Digital on the sound settings on the Directv satellite box. Problem went away.
Not able to scan stations
I don't understand why you would bother to scan channel when you have directv or dishnetwork???
directv or Dishnetwork required their units in order to watch any channel,which means:
A. Depending on your TV setting,if you use RF connection from your basic directv to the tv,you would have to leave the TV on Ch.3 or Ch.4.to view the rest of the channels,you have to change it from the directv or dishnetwork box. You are NOT able to scan the rest of the channels from the TV,bottom line!!
If you have comcast or your local cable provider,once you have activated,you could use the RF signal coming out from the wall plate straight to the tv and go to TV auto programming,it will auto scan the available channels for you.
Don't waste your time on directv.
If you are thinking about recording from your BASIC directv or dishnetwork box, you would connect SAT. signal from the wall plate to the directv box,then use composite video/audio output and connect straight to your VCR/DVD player under composite video/audio input. Now you could record the viewing channel to the VHS.
Aug 19, 2007 • RCA DRC8335
Top Directv Televison & Video Experts
Alexander
Ngoro
john h
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
