That one is pretty self-explanitory. You need to find where the Bank 2 Camshaft Position Sensor (CMP) circuit is shorted to ground and repair the short.
when installing an aftermarket radio, you will have a wiring harness with the new radio. you will have to buy seperate an adapter harness for the vehicle you are putting the new radio in. these wires are usually labled. Just match the colors with colors. watch for solid colors and the wires with stripes on them. The solid ones are positive and the one with stripes are grounds. Its pretty self explanitory once you start doing it
If you are Replacing the REAR BULB Look Along the RUBBER SEALFOR 2 SCREWS and REmove them this will Free the INTIRE TAIL LIGHT and Give you Access to the Bulbs.it is self Explanitory After this. If it is THE FRONT BULB Open hood and Look at the top of Headlight Lense Just Behind it but On TOP and REMOVE the 1 10mm Bolt to Free the Intire HEADLIGHT and you will See the Turn Sygnal BULB on the OUTSIDE END of the HEADLIGHT LENSE and It TOO Is self EXPLANITORY.
remove the bumper, you will then see the bracket that holds the bottom of the light to the car. the rest is pretty self explanitory once the bumper cover is off
There may be a way to open the sunroof manually by turning the motor with a tool. The motor could be broken and "free spinning" or it could be off track or something is stuck in the track. You just need to take it apart starting with the interior trim the rest should be pretty self explanitory. You may also be able to find a diagram on www.autozone.com.
Under your rear seat in front where you put your feet, there are 2 plastic tabs you pull down on to release the seat, from there lift the seat up.
Then if i remember correctly, your going to need a wrench to take out to bolts that hold the back of the seat in, and from there its pretty self explanitory.
this is the relay that you need. it is pretty self explanitory as long as you have some basic technical back ground. Just find the part that looks like this one and replace it. Hope this helps.
