Computers & Internet Logo
s
sandra grider Posted on Oct 18, 2016
Am using very old Psion workabout Mx. (can't get management to replaced) I have one that gives err message "Device Does Not Exist". How to I clear this so I can reprogram ? thankyou
I have psion workabout pro3 its show backup battery very low how to charge
https://www.barcodesinc.com/psion-teklogix/part-ps1050-g1.htm
https://www.barcodesinc.com/psion-teklogix/part-wa4003-g2.htm
have you got the charging cradle ?
it is part number WA4003-G2
search on internet for it with the part number
and the power supply
part number ps1050-g1
5answers
Psion Revo replacement restore
What do you do if you no longer have access to a Psion, but need to access some data from an old Psion backup on your PC? Native Psion files can't be read on a PC, but fortunately, there are some solutions:
  • Use the PsiWin PC connectivity suite to convert the Psion-format files to a format that can be read on the PC.
  • Download and install the Psion ER5 emulator - this gives you a Psion machine on your PC, and will allow you to access your old data on a PC - See our emulator setup page. From the emulator, you may be able to print or export your data to a text file, or use a third -party Psion converter
  • Consider borrowing or buying an old Psion machine, loading the files onto the Psion, then printing the documents or data as a text file
  • Find another friendly Psion user that may be able to convert the file into a format that can be read by a PC for you. If you don't know of another user, try asking for help in our Psion forum
also
Data conversion for the Psion can be quite complicated, due to the file formats used by Psion / Symbian. You should find that the PsiWin program supplied on CD with your Psion machine can help you with most of your conversion needs. If your PC is connected to your Psion, dragging files from "My Psion" to the PC should prompt you to convert to a PC format, otherwise you can convert files that are stored on the PC, using the Psion File Converter. This program is installed with PsiWin and is located in c:\program files\Psion\PsiWin - the application filename is Cpycnv.exe
psiwinconv.jpg For more help on file conversion, see our dedicated conversion page.
Agenda and Contacts databases: Note that these can't be converted using the Psion File Converter - PsiWin supports synchronisation of these files, but not direct conversion. See our suggestions in our Backup FAQ. The most common solution is to load up the files in the Psion Emulator, and either use Print to save the data as a plain text file, or use a Psion-based converter, as detailed on our Conversion page
Need to program old scanners
Hi there !
I am proff engineer on these handhelds... call me on 972 955 2739 to get help on this...
Thanks
When the unit is on the screen is frozen and will not let you do
with power off, hold down 4 and 5 key than hit power than release 4 and 5 key.
1helpful
2answers
2helpful
Workabout pro wont turn on even with full charge
Make sure that the battery cover screws are in closed position. There is sensor that cuts power to device if battery latches are not completely closed.
Special communications
press the psion_key and the x_key at the same time
Top Psion Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Psion Computer and Internet Expert? Answer questions, earn points and help others
