How to Make my Desktop Icons Small, Big, or Invisible?
Posted by Thomas Casey on
  • Jim Drosdick Oct 22, 2016
    Hi Thomas Casey, I want to help you with your question, but I need more information from you.
    What operating system are you running?
1 Related Answer
Bemal
  • 10 Answers
SOURCE: My Desktop icons and taskbar is invisible and not
This is because the explorer.exe process is not running on your computer, you can start the service from the task manager
Press the "ctrl" " , "alt" and the "delete" key together on your computer, it will open up the task manager, you need to click on the file option on the left top corner of the task manager window and select the option new tasks and then type in explorer.exe in that window and click on ok. This will solve the problem.
Posted on Jun 18, 2011
How do I decrease the size of my desktop icons?
To help you decrease the size of the icons that appears on the desktop, please follow the steps given below:
-Right click on the desktop and click 'View'.
-Now you will get 3 options as Large icons, Medium icons and Small icons.
-You need to click on 'Small icons'.
GuruAid.com
Mar 17, 2016 | Computers & Internet
I want to small icons from desktop
try right click screen look for view in its list there should be small icons
Feb 27, 2015 | Dell OptiPlex GX520 PC Desktop
How to reduce ddessktop icon size?
hey wassup
theres two ways you can go at this.
1. right click on an open area on ur desktop and just adjust the icons when u hover over the [view] option
2.make sure ur desktop is the only thing visible and give it one click on an open space just to make sure nothing is selected. then hit ctrl+&
at this point to test if it's working. hold ctrl then start to move your mousewheel on your mouse and the icons will start to all magically increase and decrease in size
now option #1 is a bit more easy and its static
while option#2 is a bit more dynamic and you can really make your icons really big or really small. it's up to you.
Nov 18, 2014 | Computers & Internet
Icons on windows desktop
You can resize the icons on your desktop as follows:
right click anywhere on the desktop and select view and then you will have the option to select different sizes for your icons.
Hope this helps.
May 06, 2014 | Computers & Internet
Some of my desktop icons have grown to be very big. I want small icons.
in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
in windows xp;
Shrinking Icons in Windows XP
  • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
  • 2 In the "Display Properties" box, click on the "Settings" tab.
  • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
  • 4 Click on "Apply" and then click on "OK."
  • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
  • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
  • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
  • 8 Click on "Apply" and then click on "OK" to adjust the size.
Shrinking Icons in Windows Vista
  • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
  • 10 Right-click on the desktop again and click on "Personalize."
  • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
  • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
  • 13 Click on "Customize."
  • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
Sep 08, 2013 | Computers & Internet
Hello Sir i have just format my laptop from vista to window 7, and the problem is my desktop icons are very big and other drivers are missing ....please help to solve this issuee..thank you
Hi
Do Right Click on Desktop then Click View & then click on small icons your icons will be small & there you will find another options of your icon to do large, medium & small.
Thanks
Mar 22, 2011 | Computers & Internet
Fn and spacebar make icons really big
Hi, right click on the Desktop Screen; select from the "View Icon sizes in the window, "medium, small..." If the solution helped, rating it is appreciated, thanks
Mar 18, 2010 | Toshiba Sattelite A105-S2071 Notebook
My icons and text have enlarged and are now too big for the screen
"Hi, right click on the Desktop screen, when the window open click on (View Icons) "Medium or Small."
Feb 02, 2010 | HP Pavilion dv2000t Notebook
My screen is showing Big Icons How do I shorten my screen.
Open Control Panel select Display click the Appearance tab then click Effects and uncheck the Use Large Icons option.
Jan 30, 2010 | Dell Inspiron 530 -IntelĀ® PentiumĀ®...
Restore active desktop
As the icons have increased in size that means ur screen resolution has changed
Goto desktop
right click on desktop  >>  Properties  >>  settings tab
now u will find the Screen Resolution adjust it according to ur requirement and u will find ur icon size small again  ( if u increase the screen resolution)
For internet settings Create a New Connection Wizard
or u can check from Network Connection whether ur Local Area Network is Enable or not.
Thank You
Vinay Ramani
Oct 12, 2008 | Computers & Internet
Computers & Internet Logo
59 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
