Hitachi 42HDT52 42 in. Plasma HDTV Logo
Question about Hitachi 42HDT52 42 in. Plasma HDTV
Connected via dtv. The picture and sound are great and it is receiving 46 channels OTA. It just won't save the channels. Once the tv is shut off I have to do a full scan again. Anyone have any idea?
2 Related Answers
Anonymous
SOURCE: no sound on hd tv on just one station
put tv on ch 2 and locate MTS button and press it till the sound comes back min English
Electrode.
Posted on Mar 07, 2008
Anonymous
  • 3 Answers
SOURCE: Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Posted on Jan 29, 2009
Did the channel scan for OTA stations, is there a way to hold these stations so I can turn antenna and rescan for more stations?
Guide to help get more channels on digital tv
spartacus-searching.com/dtv.html
Orginally there were many tv stations but the government decided to force ... Alsothese televison signals are more difficult to capture than before with analog signals. ...So that's not accurate when we are trying to find a TV transmitter. ... web page will tell you rescan for channels, thats great if you raise your antenna or have ...
How to sharpen digital TV reception via antenna
1helpful
Is the TV Tuner in the 8806 analog only? It cant be used for OTA DTV?
GPX KCL8806DT television receiver has only an analog broadcast tuner to receive digital from Time Warner you will require a converter box.
I have connecting TV link with coax cable from my sky box to my LG 50PH660V 50-inch Widescreen 1080p TV But I can not get the sky to come on my TV. as channel 68 is DTV and on my remote it says TV/RAD
If I understand your problem the Y splitter is a passive splitter which mean that the centre pins are connected via capacitors this will degrade the picture on one or both outlets, the Sky box should be connected via a scart or HDMI connection
Got a new hd reciever. can't get hd channels
First make sure your receiver is connected with one of the following.. HDMI (one cord resembling a usb cord but shaped on the ends a little diffrent) or Component wires (this cable is made of 5 wires red and white for sound and red, blue, green for picture) these are the only two ways your receiver will deliver true HD.. Once you've verified that your receiver is connected with one of those methods if you are still not receiving your HD channels you must call your cable provider and tell them there is a code missing from your account.. The cable system has codes that interact with your equipment that tells your receiver what you are allowed or paying to watch in your case the code for HD is missing.. Remember a normal coaxial cable will not deliver true HD from your receiver to your tv. Although that cable does bring the signal to your receiver. There's a good video that can teach you a lot about how this stuff works, might be worth looking into.
Fix your Own cable Save Big Money
2helpful
Vip622 doesn't lock in all of the channels on the over the air antenna .Receiver locks in 8 of 10 Channels. Three days ago, the receiver locked in all 10.
Hello! Daniel Busa with Dish Network's customer service. When you run the scan you must select ok to save the changes. I f you're still having trouble check your ota setup, and perform a hard reset by unplugging it for ten seconds.
1helpful
2answers
Why can't I tune in new channels from set top box through vcr?
Sounds like you are trying to receive the new Over The Air OTA, digital ATSC signals on a VCR that can only receive analog NTSC, which are not sent by any but low-power channels. Did you miss the change over last April, postponed from Feb, and featured on every TV channel when you could have obtained 1 or 2 $40 coupons toward ATSC-to-NTSC converter boxes. Try www.dtv.gov for more info, IIRC.
If you are speaking of cable TV then see your company. These may be digital Quadrature Amplitude Modulation QAM signals that only certain TVs can decode provided they are not encrypted. Locals are never encrypted. This is separate from the ATSC conversion.
-Ken
1helpful
2answers
I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
Great Picture But No sound
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
