Cameras Logo
Question about Toshiba Cameras
I have a Toshiba DKT2020F-SD and would like to always have my phone on call-forward to my mobile? Please help
Lawrence Oravetz
  • Toshiba Master
  • 10,558 Answers
Look in the front of your phone directory to find out how to do call forwarding in your area, or call land line phone company and ask them.
Posted on Nov 02, 2016
Toshiba dkt 2010-sd voice mail doesn't answer
To help you I would need to know what type of Toshiba main cabinet you have. If you have a CTX or CIX it may be that your system call forward is turned off. If you dial #620 at the extension in trouble it will turn the system call forward on. #621 turns it off. The proper sequence for "No Answer Call Forward" is Press ext. button + #6031 (tone) + dial main ext for voice mail + timer (08~60)
(tone) . #6051 removes this type of forwarding.
Toshiba DKT2010-sd calls no longer go to voicemail
go to the website http://www.telecom.toshiba.com/ go to the call forward settings in the book turn off Call forward All and turn on Call Forward NA (No Answer) by default it should go to the VM system. If it does not figure out what you dial in the keypad when you want VM to answer.
TOSHIBA MODEL DK3210-SD we forwarded calls during lunch and now can not get them to disconnect..even using the codes provided
you probably could have a nite button on your telephone. Depending on the type of forwarding you set ( there are over 5 different types) you have to select the right one to turn it off. Go to http://www.telecom.toshiba.com/ and view the users guide
How do I forward my phone (DKT-2020-SD) to voicemail?
This does depend on which Toshiba phone system your phone is connected to
Here are a couple possible methods
Press button
Dial 601(all calls) or 602(busy) or 603(no answer) or 604(busy/noanswer)
Dial voicemail access code(extension number of voicemail)
Press button to end
Press button
Dial #601(all calls) or #602(busy) or #603(no answer) or #604(busy/noanswer)
Press button to end
How to insert MicroSD Multi SD Kit into mobile
our micro sd multi kit will have the smaller micro sd card mounted on the bigger adapter.what you need to do is unlock the micro sd on the side by moving it forward or backward.once you have done that you can take the smaller micro sd card out and this card will fit exactly into the card slot of your mobile phone.
Jan 14, 2010 • Cell Phones
1helpful
I have DKT-2010SD toshiba business phone. how can i do a call forwarding for after hours?
There is a couple of way to do this. If you are trying to call forward the lines to a outside extension you will have to press Intercom #6011 9 (your phone number you want it to go to) then redial. Your second option is to get call forwarding through your telephone provider. Usually this is a low cost addition and is the way I would forward calls externally. Hope this helps.
Receving data from bt device are not moving directly to sd card
i think that you should move the files that were not directly moved in the sd card (move those files to the sd card)cuz that always happen to me...then i did not understand the first question.. were you talking about downloading files and then those files werent put in ur sd card...cuz i have a solution for that..
How do I forward all calls to an outside phone number? We have a toshiba dkt2020-sd phone system.
This is a feature that your local phone company will be able to help you with. The feature is called 'call forwarding'. After you purchase the feature, they will give you instructions as to what you must do to activate/unactivate it.
2answers
Toshiba DKT 2020-SD without a manual!
The phone you have DKT2020-SD can be used on many different Toshiba phone systems. For a phone all you will find are user guides. You need to find out which phone system you have and look for the manual for the system. All the Toshiba phone systems say "Toshiba" plus the description on the front cover. Example: "Toshiba Strata DK-280"
Not sure what you plan to change but programming can be quite difficult if you have no experience with it. It does depend a lot on which system you have. Many of the newest systems require special programming software.
Top Toshiba Cameras Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
ADMIN Eric
ADMIN Eric
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
