GPX 32" Thin LED Full 1080p HDTV with Built-In DVD Player Logo
j
james l lee Posted on Oct 16, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When viewing football games or golf programs the screen cuts off extreme sides f picture. EG player names, time details, scores etc. how do i fix?
Rod
Level 2:
Champion:
  • Expert 224 Answers
  • Posted on Oct 16, 2016
Rod
Expert
Level 2:
Champion:
Answers
224
Questions
0
Helped
46247
Points
493
Change the picture mode to a smaller view size,prob in menu,or a button on remote
1helpful
How do I adjust the picture size on my Mitsibishi tv. It is too wide and might be too tall. I cannot find aspect in the menu.
On your original TV remote look for button that says Picture size, Format or Ratio and press it till you see the normal size.
1helpful
Vizio M55------- will not show football scores,time,info
Find the Aspect ratio button on the TV remote. Press it a number of times to cycle through the options. Stop when the picture is the shape you want.
Have a read of your TV manual. Stuff like this is detailed in there.
Emerson plp42w10a
You are listed under DVD but I am assuming that you are talking about a TV. Most remotes have a button for adjusting the picture size. If not then go into the menu, into video settings and select the picture style there. How it is listed is different for every brand.
4helpful
Picture aspect ratio? Picture is too big for
Try VIEW MODE button on the remote or ZOOM button on the remote from cable box.
1helpful
3answers
Picture doesn't fit on my Samsung HDTV
after searching around on both remotes for me...im with verizon. Using my verizon remote under... settings-video settings-sd override...then into stretch mode fixes problem! Hope this helps anyone else with same problem!
1helpful
Moving objects extremely blurry in SAMSUNG LCD-football, golf,etc
This is a problem that will pretty much just be there on this TV. I know it has an awesome picture...as long as nothing moves. You can try putting it in "Game Mode" in the user menu and that usually takes care of it but you didn't buy the 120/240 Hz tv to watch it in 60Hz. I would say exchange it, and in my opinion buy a good plasma :)
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Top GPX Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
