Question about Stihl Garden
Stihl FS45 Bush cutter repair & Service manual Download this manual
I was given this weed eater in a basket, I really haven't found anything wrong with it. But I am Missing some hardware & screws I need a Illustration drawing to find out what is missing
Posted by Ronnie Patterson on
5 Related Answers
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Stihl FS 110 brush cutter loop trimmer
Check the fuel filter, you are not getting fuel so therefore the spark is not getting anything. You can also take some carb cleaner and clean your carb. This is a common carb issue and it needs either a new filter(recommend) and also some carb cleaner shot through the system
Posted on May 18, 2009
Anonymous
  • 14 Answers
SOURCE: my stihl weed eater will start but not rev up
little cable with toggle on the end of it, this has come off the carb
Posted on May 10, 2010
Anonymous
  • 53 Answers
SOURCE: weed eater bogs down
Under what conditions does it bog down? When it just idles? Cold or hot? When you give it gas? When you try to cut?
Posted on May 11, 2010
alpug
Danilo Baraquiel
  • 1961 Answers
SOURCE: I need to down load the ower manualfor troy bilt
here is the manual. Just click the file to download instantly.
1. 769-04481_TB539E_Operators_Manual.pdf
Please don't forget to give this answer a four thumbs up rating.
Thank you for using Fixya.
Alp
Posted on Sep 25, 2010
Reyes
SOURCE: Weed-Eater
head is more than likely worn.try replacing
Posted on Jun 15, 2013
Missing power cord to weed eater what can i use to power it up?
Most electric weed whacked use an extension cord....just plug the end into the weed eater
Oct 07, 2016 | Garden
Parts and repair manual for a Stihl FS45 weedeater
most times it is easier to do just that
Sep 23, 2016 | Stihl Garden
How to replace primer bulb
Shauna, Primer bulb replacement. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb In Line Replacement Weed Eater Toro
HOW TO Replace the Primer Bulb on Weed Whacke
Weedeater Primer Bulb Replacement
Stihl FS55 Primer Bulb Replacement How to Replace Stihl FS45 FS55 FS65...
Jul 28, 2016 | Garden
I have a Stihl Weed eater will a FS 45 carburetor fit on an FS 90
NO. The FS90 is a 4mix engine and the carb has a (sump) on it which has a pulse pipe going to the bottom of the crank. The FS45 is a totally different carb configuration, and doesn't have the sump. FS90 carb is an C1Q-131A
The FS45 has several carbs that fit:-
C1Q-S97
C1Q-S71
C1Q-S66
C1Q-S58
C1Q-S44A
C1Q-S53A
Apr 13, 2016 | Stihl Garden
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
How to line the feed on Stihl FR 106 Weed Eater Max 420 head
could you add a picture of the particular head you're using.
Aug 22, 2014 | Stihl FS 85 Weed Eater
Garden Logo
Top Stihl Garden Experts
ray gallant
Thomas Perkins
Thomas Perkins
bryan st
Are you a Stihl Garden Expert? Answer questions, earn points and help others
