SOURCE: panasonic nv gs5 digi video cam flip screen not working
Yes. It probably shorts in the wiring in the hinged area.
SOURCE: when i flip open the side view finder, i get a
It sounds like the ribbon cable has worked itself loose either on the flip or the main body of the camera itself.
If you are confident that you can can take the camera apart and check the cables then all you will need is a set of precision screwdrivers, patience and steady hands as you will be working with delicate parts.
If your not confident with repairing yourself then i recommend that you take the camera to a specialist.
Regards.
SOURCE: I have panasonic PV-GS32 camcorder. The lcd was
It does look as if your LCD screen is dead, they are not cheap to replace, but you could pop it in to your local Camera shop, they will mostly be glad to help you.
