Question about Orion1934 19" TV
I need a users manual for Orion TV Model #TV1934 August 2002. There is another number of 065320824321B. Thanks.
Posted by Starla Brooks on
5 Related Answers
Anonymous
  • 1139 Answers
SOURCE: orion tv1934 19" Has Sound but no Picture
This could be an indication of the horizontal/High Voltage stage having a problem. You are going to have to take ths to a shop to have it fixed since the HV section can kill you if you do something wrong. There are however some checks you can do if you had a schematic.
Posted on Sep 08, 2007
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: Orion TV, Model STV2763A
This is usually caused by some of the electrolytic capacitors in the vertical deflection amplifier and in the blanking circuit areas. Sometimes it can be some of the other types of components going slightly off specs.
To test the capacitors, an ESR meter or the equivelent is required.
I would suggest sending the TV out to have an experienced TV service tech do this type of work for you. These types of problems can get very involved. There are also some serious safety issues when working on a TV set.
Jerry G.
Posted on Jun 10, 2008
Anonymous
SOURCE: Need the user guide for Orion vr213 vhs player:
i have lostthe user [email protected]
Posted on Mar 05, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Are my Orion tv's purchased in 2002 digital ready
Your TV does not have a digital tuner. You'll need a converter box for digital broadcast reception. Remember that if you're on a cable system or using a satellite receiver, your TV doesn't need to have digital tuning. It's only if you want to watch off-the-air broadcasts that you'll need the converter.
Posted on May 12, 2009
Anonymous
  • 123 Answers
SOURCE: have 8 yr old Orion tv-new remote control for
We would be happy to help you with getting your new DISH Network remote to control your TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your Orion TV; here are some of the codes we currently have for it: 720, 748, 748, and 748. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Orion TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Posted on Mar 09, 2011
I have a Trisonic Ts -tc 443 universal remote and
0281,0229.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 14, 2014 | Televison & Video
Where can I download the user manual for Orion TV Model TV22LB830H ?
I found the support site! Finally, whew! Orion owners needing to buy a remote, or download a manual, go here: http://www.sansuiproducts.com/accessories.html
Oct 05, 2012 | Televison & Video
I have an sony rm-ez2 and i want it to work with my orion Model #tv1934 whats the code or will it work
As far as I can tell, Sony doesn't have any codes for Orion TVs. You can try searching through all of the codes in the remote. Turn on the TV, press and hold the Set button and then press the Power button. Release the buttons. Then press TV button (component button). Press the CH+ button followed by the Power button. Repeat the CH+ and Power combination until the TV responds (powers off, changes channel). Then press ENT. Check if the TV responds to the remote on other functions. If it doesn't repeat the steps from press and hold the Set button.
This can take up to 70 tries.
Alternatively, try a replacement remote for the TV or a USB programmable universal remote. http://www.remotes.com/store/orion/tv1934.html is a substitute remote that should handle all of the functions.
I hope this helps.
Sep 06, 2010 | Sony RM-EZ2 Remote Control
I have an Orion TV1331. change to video without remote....?
The only way to switch it from TV to video is with the remote control. Orion did not have many onboard controls.
Oct 14, 2009 | Televison & Video
May 12, 2009 | Orion STV2763 27" TV
Manual
I need a schematic for orion tv1934 board# tma525a
Mar 19, 2008 | Televison & Video
User manual needed
sorry this is all I could find with out a model #
http://www.orion-tv.net.au/Remotes.pdf
http://www.orion-tv.net.au/manual/20VROT.pdf
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 07, 2008 | Televison & Video
User manual needed
Manufacturer's Phone Number may be 800-289-0980. Not sure if this is the manufacturer number, but it is the number listed on the Orion TVDVD092 box to call if you still have questions after reading the manual. I need a manual as well. I do hope that they will send me one.
Jan 02, 2008 | Orion TVDVD092 9 in. TV/DVD Combo
Orion tv1934 19" Has Sound but no Picture
Sep 07, 2007 | Orion1934 19" TV
Orion1934 19" TV Logo
323 people viewed this question
Top Orion Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
