Swipe in from the right edge of the screen, and then tap Search.
(If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, and then click Search.)
Enter sign, and then tap or click Change sign-in options.
Choose the sign-in option you'd like to use, and then follow the instructions.
Samsung Smart PC, also called Samsung 700t, is installed with Windows 8 operational system.
1. If you have created PIN code for Windows 8 logon, when the Windows system prompts you that your login password, you can change to select login Windows 8 with PIN code. It is the easiest way.
2. If you don't have PIN code and another administrator account, you can think about third-party password recovery software. Here, I recommend you Windows Password Genius. And this is a software you just need USB device and accessible computer. I just learned from here Get access to Samsung 700t after Windows 8 password forgotten .
When you are locked out of HP Windows 8 laptop, how to unlock HP laptop and login into Windows 8 successfully without password?
Follow this video and learn how to use Windows Password Genius Advanced to reset HP Windows 8 admin password.
First hit f 8 just as the windows window comes up. Hopefully he did not set an Administator password.Otherwise you need his password or you will have to reinstall operating system. If you get in as Admin change other passwords
the best way to delete vista is with a windows 98 boot disk and format the c drive. If you have a disk the correct command at the prompt is "format c:" then press enter
You can double click on the printer icon on the bottom right of your screen on the status bar.When your printer opens up, Select printer and then cancel all print jobs. Depending on the printer you have loaded, you may have to select the properties menu and delete all the documents.
Have your HP
laptop login password forgotten? Do you have another administrator? Have you created
Windows password reset disk on your HP computer when it is available? Or
whether you have installation CD?
If you have
administrator, just change HP login account to this administrator and access HP
computer with it. At this time, no matter which account, you can easily change
or remove its password on Control Panel.
If you have
password reset disk, on Windows login screen after you type incorrect password,
there will be a message "Reset Password" prompting you to reset forgotten
Windows password with reset disk. Just follow password reset wizard to do.
If you have
installation CD, it will help you to restore HP computer or repair computer.
But it is still dangerous for us to use it because it will delete some
important data on your computer.
In consideration
of data safe on computer, Windows Password
Genius provides a safe Windows password reset environment WinPE. With it
and in such password recovery environment, you will don't need to worry about data
lost or damaged.
