You have hacked or infected files on your computer. Check your BCD and do the below fix if necessary (at your own risk)
In Windows open CMD as Administrator and type BCDEdit and enter, if your Windows Boot Loader Path is xOsload.exe then you need to remove some files and repair your BCD.
NOTE: you will need to re-activate Windows afterwards, so make sure you have your Windows 7 key handy. Boot to Windows Repair - Command
Del D:\Windows\System32\xOsload.exe
Del D:\Windows\System32\xNtKrnl.exe
Del D:\Windows\System32\Drivers\oem-drv64.sys
attrib c:\boot\bcd -h -r -s
ren c:\boot\bcd bcd.old
bootrec /rebuildbcd
This error codes indicates that one of the toner cartridges you have installed does not contain a valid chip on it. If you recently changed a cartridge that is the likely culprit.
That error indicates that there is a problem with the cartridge rotation motor. This is not something you can repair yourself. You can check and make sure your toners are fully inserted and that the carriage is not jammed, also check the transfer belt and make sure it is installed correctly. Other than that this will involve disassembly of the printer.
49 error simply means that the print job that was sent contained information that the formatter on the printer was unable to understand. This is most commonly caused by out of date firmware.
If you are using windows go here and download the easy firmware update utility and then run it. This should fix your problem.
