Uniden Cordless Phone Logo
Question about Uniden Cordless Phone
WDSS5315 old phone functioned perfectly well until today when it no longer allows input of numbers and cannot be disconnected when a call comes in.
No error codes. Just stopped being able to dial out mid call. Receives calls, but can't make any. Can't conclude a call pressing red end call key. Battery fully charged.
Posted by Diana Woodward on
5 Related Answers
martin hogg
  • 157 Answers
SOURCE: Handset Buttons Stopped Working - Full Battery
Here is a link to Uniden's site, and on the right side of the page, there is a link for a download manual pdf and helpline
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
also worth checking if any buttons are stuck, or if the handset is set to pulse rather than tone mode, or if it has had a tumble or knock, possibly the keypad connector has come loose .
Hope this helps.
Posted on Jan 16, 2008
Anonymous
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
Anonymous
  • 76 Answers
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Posted on Dec 02, 2008
Anonymous
SOURCE: Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Posted on Jan 08, 2009
Anonymous
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
I bought a new LG 3 verizon phoneand prior to that ihad a different phone with a different phone number now that I am trying to retrieve my facebook account that was set up under my old phone with my old...
Hi
You could try this, go to the login page here:,
Facebook
just under where you input your password you can click on "forgotten password". This takes you to a page where it says "find my account" where you can enter "Email, Phone, Username or Full Name". (Probably not Phone in your case !!) Try entering one of these (My email gave the best result for me) and follow through the instructions to reset your password so that you can access your account.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Acer aspire using windows 7 will not allow me to log in using the same password used for the past 4 years?
Once encountered a situation where a function key was stuck (don't remember which, probably a Shift).
I repeatedly pressed all function keys individually, several times.
Problem gone.
Just got the phone today, it was acting fine until I disconnected the charger. Now the back light goes out after a couple seconds every time I try to use it. The light comes back on when I press the...
Try changing your display time out to something longer. Select menu-> settings-> display -> screen timeout -> pick something longer.
You can also set your brightness to not automatic. Within the same display menu, select brightness and uncheck the automatic brightness box. See if that works.
Lewis
Unineden owners manuals mod no.s DSS7855 WDSS5315 CAN NOT FIND THESE
DSS7855: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/DSS7855_1_2_OM_Final.pdf
WDSS5315: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/WDSS5315_1_OM.pdf
2helpful
I have a Prostar 816 Plus. I disconnected the power cable today to connect it to a new battery back up surge protector. I then tried to dial out and it sounds like an old rotary phone. It allows me to dial...
To change the dialing from pulse to dtmf dialing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #42 the screen should momentarily say trunk dial typethen display the current programmed data (00000000)
3) enter in 0 for pulse dialing and 1 for dtmf dialing for each of the lines. i.e. touch tone dialing for lines 1-4 would be 11110000. all 8 digits must be entered for the program to accept the data
press # when finished.
7helpful
4answers
No dial tone on Uniden Dect 6.0 land line and portable phone
We've had the same problem with our new Uniden phone. Sounds like someone's on the other line - no dial tone and answering machine doesn't work. The telephone line works though because we plugged our old phone in and it works fine. Any solutions anyone?
Top Uniden Lands Phones Experts
Muzahura Frank
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
