I have Catz 5, and I wanted to uninstall and re-install to clear some things up.. However when I pulled up the Control Panel and the InstallShield Wizard popped up, and I selected uninstall, it simply displayed the Generating List of Files to Delete... message for literally hours without ANY progress. No matter what I try, this happens over and over again. So I would like to manually remove it. My Catz 5 files were placed in Local Diskc: because I have Windows 10 and that's the only way it would let me play the game. Does ANYONE know the main game files specific names so I can hunt them down and delete them? :
SOURCE: Catz 5 problem with installation.
if you are trying to install the game from a CD or DVD the cause could probably be that the CD or DVD is damaged, try cleaning the media. if u are trying to install the game from a cd or dvd try coppying all the files on to your had disk and then open the setup procees from the hard disk.
SOURCE: Petz 5 help!
at the moment you either would have to create new petz or try installing the game again. the way to see if you saved them is to go into the saved petz folder and find files of your animals , if they are there unlock and download any zip files and they should do it for you
SOURCE: Cannot install or play Petz 5!!!
Delete or rename Program FIles\Common Files\Installshield I did that and it works.
SOURCE: dogz 5 not installing!!
then the problem is not with ur computer but with ur cd. use isobuster and create an image of the cd. then mount it. now u can run and install it. there is an easier way get a new copy of the software
