Any onkyo AV amp remotes can work well . I use onkyo TX-SR600 remote to control RZ800. It works so far so good. A remote for SR807 works well in SR333 also.
I had the same problem with my TX-SR601 receiver. Solution: I changed the
capacitor C766 (100uF/6,3V) on the "DSP and main microprocessor" or "U1" board. This
capacitor is responsible to keep the settings in the memory. It is directly
next to the SRAM ICs (Q705-706) (type: CY7C1019BV/CV33-15VCT).
Now the receiver works properly again.
For all practical purposes an EQ or any analog audio processor connects exactly like a Tape Deck - into any RCA pairing that has both an OUT and an IN and can be selected to be in or out of the audio path.
However, on this and just about any modern digital-capable AV Receiver, activation of any external loop that would connect a processor or tape deck would automatically DISable any digital audio sources. The effects of the processor, therefore, can only be used with analog stereo sources. It WILL affect the sound going to all speakers if you use the various Digital Sound Porcessing modes as the extra channels are derived from the stereo channels anyway.
Any analog processor can occupy the Tape Out/In loop. However, it will only affect stereo analog sources and, once engaged to monitor, it will disable any digital audio source.
An external amp COULD be slaved off the tape Out (or the anticipated EQ Out, but it won't be volume-controlled by the Onkyo. You would need an AVR with at least Front L/R pre-outs.
All you have to do is get a 3.5mm plug to two RCA plugs lead and plug the 3.5 Jack in the headphone socket of your ipod and the two RCA's into an aux imput and away you go. If you get one of the small docks, that will stop the battery running down, but you don't need one.
By the look of the picture on FixYa it looks the RCA's can go in the front socket under the volume control.
Have you connected the Subwoofer out to the "Pre-out Subwoofer" on the left bottom corner jack(looking from the back)?
Have you set subwoofer out in the menu(under speaker settings or similar menu you will find all the channels that you have connected and here you should have "YES" for the subwoofer)?
you can do it passive. no idea with your ampli, but if it does have a bridge then you can hook your eq there, series. if it doesn't have then via tape monitor 2 of your kenwood.
onkyo recvr tape 2 record to - kenwood eq in
onyo recvr tape 2 playback - kenwood eq out
that's all. if you want your eq to be active, then switch your reciever to tape2, all selected input in your reciever will by pass through your eq then back to kenwood. you dont have a function for tape 2 input then but your eq will have an extra input for tape, that you can use for your second tape, it will be active only if your reciever is set to tape 2. i hope you got it right.
