Do you mean the bearing on the motor shaft within that circular plastic ring that moves up and down when moving the slicing thickness lever? If yes then a couple of screwdrivers under it one on each side to lever it up. At the same time it will force the black shaft sleeve up and off the motor shaft.
SOURCE: Plastic housing cracked Cuisinart DFP-11 Deluxe food processor
Cuisinart does, in fact, have the replacement bowl parts for the DFP-11
SOURCE: my kitchenaid processor is not working
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
SOURCE: I have a kitchenaid food processor and the bowl is
Items required:
-dishwasher
-detergent
-lemonade or other citric liquid
-poochy
-skillz
Step 1:
gently position poochy around tube in center of bowl. Fill halfway with lemonade or other citric liquid.
Step 2: Put lid of processor on and put entire unit in dishwasher. Turn on power scrub cycle.
The dishwashing cycle will help the citric acid to activate the poochy.
Step 3: Use skillz to wriggle the bowl off the processor. Empty out poochy remains.
Congratulations! YOU'VE GOT SKILLZ!
SOURCE: How to remove motor shaft sleeve from KitchenAid
I just did this. I used a screwdriver and some needle-nose pliers to wedge and separate the shaft from the base. Once you've separated it by about 1/2 inch, it will come off easily. I simply used a mallet to install the new one.
SOURCE: My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Testimonial: "really helpful thanks"
