Freezers Logo
Cathy Foust Posted on Oct 13, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Refrigerator side frost build-up.
Refrigerator side of ref/freezer commercial grade combo has frost buildup on top interior. It melts when door is frequently opened and closed. We've had defrost timer and gasket/seal replaced. One service person says we need a new compressor, another says a possible freon recharge. It is a very old unit. What could be the problem, and is it worth the cost to repair or should we just replace?
Marvin
Level 3:
Top Expert:
  • Continental ... Master 85,242 Answers
  • Posted on Oct 13, 2016
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29037496
Points
266281
Every one of the issues the techs gave you are possible solutions.
2answers
1helpful
Kenmore Freezer 106.727581: The freezer ices up and the temp goes up to 34 degrees. If I manually defrost it, it goes to 5 below zero in about 6 hours. How can I determine which of the below need to be...
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater. To determine if the defrost heater is burned out, watch this part testing video
Frost build up shortly after defrosting it.
the frost buildup is entirely due to badly fitting seals,its also costing you a fortune to run it.A 5 sided cube is easily adjusted by using a spirit level and spacers under the feet/wheels(if fitted)once adjusted the lid should fit square.otherwise check the hinges for adjustment.
WHEN FITTED/INSTALLED CORRECTLY, THE LID SITS TIGHT ALL ROUND,NO AIR GAPS.....
Frost buildup around the inside top of the door of an upright Frigidaire Commerical Frostfree Freezer Mod# FFU20IC8Cw2
This happens when your thermistor gets frozen along with the coils or there is a clogging of the freezer drain which causes Ice to build up and spread to the system. Another issue is that your thermistor may be faulty, telling the system inaccurate temperature. Incorrect freon pressure can also be a cause. I would advise first to have the ice melted by letting the unit stay unplugged and have it cleaned while at it.
1helpful
Freezer wont freeze, compressor always running, refrigerator not cold
HI,
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 • Freezers
Freezer/refrigerator
Refrigerators with an evaporator (called a humid plate on this type of refrigerator) in the refrigerator section are called a semi-automatic defrost. This means that the freezer section occasionally needs defrosting but the refrigerator section defrosts by a means called "heat leakage defrost". How it should work....
the cold control, (the electrical device under the dial), leaves the compressor off for long enough for the plate to melt off each cycle.
If yours is not melting off perhaps you have a faulty control or you have it set too high. hope this help
Frost buildup in frost free freezer
There is a defroster built into the ice maker to melt the ice a little around the edges before dispensing on most ice makers it may need replacing.
Jul 28, 2008 • Freezers
Top Continental Refrigerator Freezers Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Continental Refrigerator Freezer Expert? Answer questions, earn points and help others
