Question about TYC Ford Taurus Cooling Fan 96 97 98 99 00 01 02 03 04 05 06 07
Want to know how to tell if my 97 Taurus 3.0 has jumped time
How can i find out if it has jumped time
Posted by Joe Sturdivant on
Ronald Irvin
    Loyalty:
    Visited the website for 30 consecutive days.
  • 9 Answers
You need a timing light....
Posted on Oct 13, 2016
Car is backfiring like no gas it has fuel injection
most times-a backfire is caused by being slightly out of time or bad valves--not sure of your year make or model of car. Sometimes the timing will jump and cause the firing order to be wrong and you'll get a backfire and the car will run ruff
Apr 26, 2012 | Delphi Fuel Pump Mercury Sable 97...
Where is the commen oil leak on a 97 ford taurus
Maybe, maybe not, It's most likely a bad rear seal or worn main bearings but check the oil filter just to be safe. Sometimes things go wrong when changing the oil filter that can cause similar symptoms.
1) old gasket left behind.
2) cross threaded filter.
3) loose filter.
4) damage gasket or defective new filter.
Jun 06, 2010 | 1997 Ford Taurus
97' TAURUS SHO 3.4 LITER HAVE THE CODE PO102 NEED TEST PROCEDURE TO FIX
inspect Mass air sensor, clean with electrical cleaner and test. should read around 3 on scanner and jump to 15-20 upon accelaration if not replace.
Apr 09, 2010 | 1997 Ford Taurus
1997 Ford Taurus flasher location/replacement
images from a 97 Ford Taurus, GL body type. Shows location of flasher and a simple removal tecnique I discovered. The alternative was insane contortion.
Jan 20, 2009 | 1997 Ford Taurus
97 taurus will not star in cold weather
I had this problem with my 98 taurus i tried jumping it wouldn't start, mine was the fuel pump check.
Jan 14, 2009 | 1996 Ford Taurus
Starting problems w/97 ford taurus
check for spark and check to see if its getting fuel.
Jan 06, 2009 | 1992 Ford Taurus
97 ford taurus GL idles and kills when putting it in gear
check the vacuum hoses and make sure none of them are off and check the timing and also the drive belt
Dec 31, 2008 | 2006 Ford Taurus
The clucth in my 97 taurus keeps trying to kick in ,how can I fix
the a/c clutch should cycle on and off 4 to 7 times/miunte depending on air temperature. if it's cycling n & off several times/minute, you are probably low on R134a. Add a can to see if the cycling lessens. get a hose kit with a gauhe on it that tells you if you are getting overcharged.
Dec 19, 2008 | 1997 Ford Taurus
FORD TAURUS 1996 RADIATOR FAN DOES NOT WORK
Test the fan by unplugging it, and jumping off the battery. This will tell you if the fan motor itself is working or not. If it works, post back and I'll tell you how to check the engine codes, a sending unit on the engine could be nfg and causing the fan to not come on. If the fan doesn't come on when jumped, replace the fan motor.
Dec 05, 2008 | 1996 Ford Taurus
TYC Ford Taurus Cooling Fan 96 97 98 99 00 01 02 03 04 05 06 07 Logo
140 people viewed this question
Top TYC Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a TYC Computer and Internet Expert? Answer questions, earn points and help others
