Sump temp sensor is not reading water temperature of water running over evaporator plate.This sensor is located in the water supply tube that runs up to the top of the evaporator plate. just pull the sensor out of the tube and replace it.
its a air inlet temp sensor code if that sensor is good check the coolant temp sensor and trans temp sensors if there not close in temp it trips the code
The F2 error code is for the temp sensor. The temp sensor is mounted inside the oven cavity & regulates the oven set temperature. If the temp sensor fails the oven could overheat. This is what generates the error codes. I recommend having the temp sensor checked with an ohm meter, at room temperature the sensor should ohm out at approx 1100 ohms. If the sensor checks ok, then the control will need to be replaced.
These codes indicate an over temperature condition. The F2 & F3 error codes both mention the temp sensor. The temp sensor is mounted inside the oven cavity & regulates the oven set temperature. If the temp sensor fails the oven could overheat. This is what generates the error codes. I recommend having the temp sensor checked with an ohm meter, at room temperature the sensor should ohm out at approx 1100 ohms. If the sensor checks ok, then the control will need to be replaced.
Trouble Code 33 and 34 are the MAF/MAP Sensor
Circuit. It sounds like you've replaced that sensor already. Did you also have the code 34 before putting in the new sensor?
Or did this code start after it's replacement? Any other codes appearing?
Troubleshooting it would depend if it has the Speed Density
Update. The dealer should be able to provide that info.
