Question about AOpen Computers & Internet
Where is the cmos battery on a Aopen barebones 1547 notebook computer please
4 Related Answers
Anonymous
  • 11 Answers
SOURCE: Apple G4 notebook CMOS battery replacement
If you turn the Laptop upside down (making sure that the laptop is not turned on at the time!) you will see some compartment panels that can be removed. Undo the screws to these and you will see the CMOS battery in one of them. Have a replacement battery ready to insert...remove the old battery and insert the new one. Put the cover back on and your done! Hope this helps.
Posted on Dec 05, 2008
Anonymous
  • 505 Answers
SOURCE: Drivers to AOpen 1849L (96NKU01G03) Barebone
go to www.driverguide.com and download the drivers from there.
Thanks
Posted on Mar 03, 2009
Anonymous
  • 1383 Answers
SOURCE: CMOS battery Gateway 450SX4 notebook
it is in back sdie of alptop.
You have to remove 4 screw on each side of square.
then you find motherbord chipset.
cmos cell is fixed on motherbord circuit.
Posted on Jul 16, 2009
SOURCE: how to change cmos battery on aopen xc cube ux45g
Although this question is really old I would like to answer it as I had the same problem a few days ago. This first answer from ikkenom is not really good, it is to general.
If your Aopen XCube UX45G forgets BIOS settings like time, boot order or other options it is very likely that the battery needs to be replaced. To replace the CMOS battery of the XCube UX45G you need a new CR2032 battery. The battery socket is a bit hidden. It can be found next to the IDE ports. See this image: http://www.informationsarchiv.net/uploads/image/8182/xccubeez65-25.JPG . First turn of the power chord, remove the battery as ikkenom described and insert the new battery. The positive pole (+) has to be positioned in the way that this pole can "see" the RAM slots. Turn back power chord, start the computer und reset BIOS settings.
Posted on Jun 03, 2013
How do I find and replace cmos battery on Clevo M762T/Sager NP7660 laptop notebook?
Your laptop CMOS battery is CR2032 and instead of writing the instructions on how to replace the CMOS battery I am posting the link where it has been illustrated with images/pictures.
http://www.paulstravelpictures.com/Laptop-CMOS-Battery-Replacement/
I hope this helps, please let me know if you have any further questions.
Best regards,
Amar Sondhi
Nov 20, 2013 | ASUS D1 500 (ap d1500) Barebone
Network driver
This barebones system is from AOpen Netherlands. They have a website for the driver downloads. Here it is:http://www.aopen.nl/products_download.aspx?sDropDownProd=4
If you like my answer, please accept it. Thank you.
Dec 24, 2010 | AOpen XC Cube EZ915 (95EZ1592Z1) Barebone
How do I reset the bios setup password on Aopen MP945-x?
switch off the system in the main board you will see the cmos battery remove them and switch on the computer and dont forget to replace the battery this will reset your bios to default after reseting you need to reset the time and date
Dec 15, 2010 | AOpen Computers & Internet
Mini notebook 7'' freezes on startup and says loading OS image
Most likely it has a corrupted registry issue and maybe you'll have to reinstall the OS from cero
Jan 10, 2010 | AOpen EPC945-m8 (95EP4596B1) Barebone
Centrino Notebook keeps asking for password
clear cmos setting on the motherboard by replacing the cmos battery if problem not solve then change bios .
Apr 12, 2009 | AOpen 1555G Centrino Notebook, 15" LCD...
Installed new ram-went from 2 512 sticks to 2 1g sticks, the comp wont boot, only the fans come on, no lights on the power button or signal to the monitor. I put the old ram back in to see if it would...
dose the ram have mem chips on both sides of the ram stick, sometimes this causes the problems, i would sugest that you clear the Cmos, maybe take out the bios batterie and leave it unplugged for couple of hours, plug it back in and see if the old ram works ok, if it dose then maybe try the new ram maybe one stick at first.
good luck.
Apr 02, 2009 | AOpen XC Cube EX661L (95EZ619321) Barebone
Vista running on AOpen Ez65
I am taking it that you currently have XP installed?  You need to boot the computer from the Vista CD.  Please note that this will erase your hard drive.  So back up any important stuff before you attempt this.
Mar 04, 2009 | AOpen XC Cube EZ65-II Barebone
Computers & Internet Logo
Top AOpen Computers & Internet Experts
Michael Thomas
Michael Thomas
Joe Goldman
Joe Goldman
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
