Question about Bunn CWTF Coffee Makers & Espresso Machines
Have a Bunn CWTF, when the switch is pushed and water begins to flow thru the basket, there is a small amount of water that begins to puddle on top of the left tank (right does it also, but less).
Replaced the tank inlet gasket and made sure the syphon tube is free. No debris was emitted from the syphon tube. The silicon tube was in place on the syphon tube and still very flexible. Still leaks. I noticed the thermostat gasket was very easy to remove. Is it suppose to be very snug? Could the gasket shrink? The maker is over 13 years old and just started this leak. We did move the maker 2 years ago, I just put a level on the counter, the bubble is between the lines, but not in the very center. It is indicating the maker is very slightly higher in the front.
Posted by Keith Thomas on
Mark Cheong
    Master:
  • Bunn Master
  • 791 Answers
Leaking from top of tank; Call for service as this is an electrical hazard.
*** the following is for information only. ***
* Replace any worn gaskets and silicone tubes.
* There may be cracks in the metal pipes. Hard to see, but there, if you remove the lime deposits.
* check the top tray nut if the gasket to the tank is missing. It's about an 1-1/4" round washer with about a 3/4" hole. Usually made of white silicone rubber. It seals the fill tray to the tank. Leaks often.
* Bunn equipment can last quite a few years (decades?) but the gaskets do get hard and the tank needs to be water tight to work properly. Since this is already an old brewer and you've saved money rebuilding it. Suggest going further by replacing all gaskets. Yes they do need to be snug with no cracks.
Aloha, ukeboy57
Posted on Jan 20, 2018
5 Related Answers
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: Water leaking from freezer
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from comming out the freezer door and leaking onto your floor and running down your copper pipe to the basement.
Posted on May 12, 2009
Anonymous
  • 4 Answers
SOURCE: my 10 cup Bunn coffee maker leaks from the top
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
Posted on Oct 15, 2009
Anonymous
SOURCE: Leaks water in the counter.
I fixed mine for 25p... you need to take the back off, and the tank holder out (2 screws each). There is a very thin pipe that comes out the pump - that is the leak.
Unclip the little clip and pull out the pipe and fish out the black o-ring out the hole.
Buy a new o-ring and put back together... no leaks =)
Posted on Nov 15, 2009
Anonymous
  • 14 Answers
SOURCE: leaking coolant from a small hole located in the
water pump failure, water pump on these run off the timing chain and the timing chain runs in oil, so they could not just put a weep hole on the pump because it would go strait to the oil pan, instead they redirected the coolant from the leaking pump to just below the thermostat housing. And good luck, it's at least a 6 hour job on these. Brandon-MO
Posted on Jan 21, 2010
atbsmmom
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Posted on May 19, 2010
My Bunn CWTF-DV-3Tisleaking water from the top right corner of my machine,and has just started leaking at the base of where the bottom burner is. Could you please help,as we have no technicians were we...
open the top. there is a trough drain that gets limed up. using a phillips head screwdriver, push through and twist, thereby removing the lime and ensuring proper flow. if water can't get through, it may overflow over the sides of the trough. also look behind the trough to the top of the tank and see if there is any water damage around the seals. if there is, replace the seals
Feb 17, 2014 | Bunn CWTF 15-3 Coffee Maker
Water is not hot when turn on
check the heat switch in the rear. if it's on, check the thermal fuse in the top right rear of the brewer. it'll be in a now browned tubing. you can get it through bunn (800) 352-BUNN (2866)
Jan 05, 2014 | Bunn CWTF 15-APS Coffee Maker
Hot water is comeing out of the spot slow
delime the sprayhead holes with a paperclip, and the trough drain inside the top with a screwdriver. this will ensure proper flow
Apr 18, 2013 | Bunn CWTF 15-3 Coffee Maker
Bunn CW series slow water flow
delime the sprayhead and the reservoir drain in the top with a deliming spring or a screwdriver
Dec 03, 2012 | Bunn CWTF 15-3 Coffee Maker
Keeps spilling over during brewing
These tanks can't actually be overfilled since all water poured in displaces the exact same amount of water coming out the spout. So, whatever amount of water you pour in, will be the same amount of water that flows to your pot minus the amount absorbed by the coffee grounds and filter.
Your problems sounds like an undersized (Non Bunn) filter, or clogged brew basket. To verify this, try pouring in only half the water for your brew cycle and wait for it to finish dripping, then pour in the rest. If no overflow has occurred, you simply have the wrong type of filter. If overflow begins again, you have a clogged brew basket, since no Bunn can flow too fast for the brew basket to keep up with it.
This is because Bunn filters are manufactured differently than generic store bought paper filters. They will flow faster, brew cleaner and stand up better than normal generic filters.
Remember, Bunn makes their OWN filters for good reason.
They made the first, best paper filters for drip coffee pots, and all others are just generic dioxin gas producing paper.
Mar 05, 2010 | Bunn VPR Coffee Maker
BUNN CWTF-15 Not brewing full pot, only 1/2 pot..?
If this problem started after moving the machine, pull the machine out a little & look behind it for a kink in the tubing coming to the brewer. These brewers time the water coming through them, so if a kink is restricting the water flow, running the same amount of time equals much less coffee in the airpot.
Oct 03, 2008 | Bunn CWTF 15-TS Coffee Maker
Coffee Makers & Espresso Machines Logo
43 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
