Question about HP OfficeJet 4215 All-In-One InkJet Printer
Error 0xc09b0002 What does this error mean
Posted by Pauline Wimberley on
I have a R 93 ami jukebox and keep haveing error codes 1and4 what do they mean
Error 4 means the memory backup battery inside the Central Control Computer is dead or very low. Error 1 means factory defaults are being loaded due to a dead battery.
Jun 15, 2014 | Wurlitzer Jukebox CD Player
What does this error mean dryer has error f-01?
The "F1" error means that the dryer's thermistor failed and needs to be replaced. Make sure you check the dryer vent for clogs before installing the new part.
May 04, 2014 | Kenmore Dryers
Error 69
Do you mean error 99? An error 69 is not listed in the manual. Error 99 mainly occurs with non-canon lenses, and indicates a communication problem between body and lens. Which still does mean nothing more than: it could be anything... Try cleaning the contacts. Or mounting another lens.
Mar 27, 2014 | Canon Cameras
Erorr code 4003 zebra zxb8
Error Code 4001
System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
Error Code 4002
System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
Error Code 4003
System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
Error Code 4004
System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
Error Code 4005
System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
Error Code 4006
System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
System Error Codes
Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
What is error 50 and 30?
Error 30 is a Head/Carriage Unit travel error. It means the printhead is not moving. Error 50 means means the Purge Cam switch does not come on. This is part of the unit, which conducts the purge or cleaning operation.
Oct 08, 2009 | Brother MFC-5460CN All-In-One InkJet...
Error code E000019-0000, trying to find out what this error code means.
Hello sir; It's means waste toner bottle full, dump it after you turn off the power, then turn power back on.
Apr 29, 2009 | Office Equipment & Supplies
Code errors on kodak easyshare esp 3
error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
for more hrlp visit CBR Tech Solutions
Apr 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
150 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
