Kyocera FS-C5150DN Duplex Network Colour Laser Printer Logo
Question about Kyocera FS-C5150DN Duplex Network Colour Laser Printer
Kyocera FS-C5150DN call service 7403:0004749 - Kyocera FS-C5150DN Duplex Network Colour Laser Printer
Posted by Alzbeta Durkova on
  • Alzbeta Durkova
    Alzbeta Durkova Dec 03, 2016
    thank you very much for your help
Marius Chiriac
  • Kyocera Expert
  • 242 Answers
this error is about the Magenta developing unit.
Please check the connection between the ptinter and the developing unit. Restart the printer after that.
If the error will not go away after that you will have to replace the Magenta developing unit.
If the error still will not go away you will have to replace the engine power board.
Best regards,
Marius
Posted on Dec 03, 2016
5 Related Answers
Anonymous
  • 2120 Answers
SOURCE: CALL SERVICE 7410:0002988
Turn printer off
open left door
push in DRUM unit
turn back on.
Posted on Feb 10, 2009
Anonymous
  • 66 Answers
SOURCE: Kyocera FS-4000DN, CALL SERVICE 6030:0159631
this error indicates a problem with the fuser unit.
if you are an end user, you will have to check warranty status with you nearest service agent and have the fuser replaced free or get a quotation if it is out of warranty
Posted on Mar 21, 2009
Anonymous
  • 300 Answers
SOURCE: CALL SERVICE 6000:0115785
Error 6000: is a fuser error 0115785 is your page count. You require a replacement fuser
Posted on Apr 14, 2009
Anonymous
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
Nikolay Boychev
  • 525 Answers
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Posted on Feb 21, 2011
Kyocera call service 4200:040797
Means that the laser unit is off. You should check the cables for the laser unit
ERROR POWER OFF KYOCERA FS-C5150DN
What is exactly the message been displayed in FS-C5150DN?
HOW TO RESET A KYOCERA FS-C5150DN
you can open the command center of the printer, login using the password admin00. Then go to tab "Basic", click Reset and choose the last one, which says Reset Entire Device To Factory Defaults.
If you just want to reset the frpo parameters to factory defaults, then use the command !R! FRPO INIT; EXIT;
I have a kyocera fs-c5150dn and it keeps saying check the toner container what does that mean
check the waste toner bottler or the other toners reset in machine then reboot
2answers
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
Kyocera fs-1920 (call service 6400:0040085) help!
the printer will require a need new fuser unit or a new power supply.
let me know if you need more help
Open Questions:
See all Kyocera FS-C5150DN Duplex Network Colour Laser Questions
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
George Mclaughlin
NADARK
NADARK
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
