SOURCE: Vin number location on a mitsubishi rosa deluxe
drivers side around where thehood meets thewindsheild or driver side door on data plate
SOURCE: Exterior rear door handle on Honda Accord 2001
To Remove Door Panel on 2001 Honda Accord:
A: To remove the plastic piece with the door lock button and door handle connected to it:
1- Remove the screw in the middle located behind a plastic cover button
2- Push (slide) the whole assembly Forward (toward front of car)
Besides the screw, it is held in place by 3 hooks on the backside that hook into holes in the metal door frame
3- Now unhook handle from small metal bar going through door by pushing (toward door) plastic clip (blue?) off of the bar, then the bar will come out of the clip hole, thus releasing the handle.
4- Depress little grey button /bar (purple painted on it)on elec. connector to seperate connector, thus releasing door lock switch
Now the whole assembly (metal handle, door lock switch, and plastic piece) will come off door panel
B: The door is held on by 2-screws, 7-plastic snaps/plugs, and 1-plastic plug.
The screws are located: bottom of hand hold and the other behind the handle, both covered by little covers that have to be pryed off to access the screws.(hint: the screw with the built in spacer goes behind the handle when you are trying to reinstall)
The 7-plastic snaps: 3 across bottom and 2 on each side. Not visible, they are mounted to the inside of the panel.
The 1-plastic plug is visible at the upper front of the panel and is the same color as the surrounding trim
C: Take off the big plastic triangle piece above the door panel and behind the mirror. Pull/pry off. It has 2 snaps holding it on. one near bottom and one near the front.
D: Light lens prys off from bottom. Unscrew (1/4 turn) the light assembly with bulb still intact from backside of panel
E: Remove the Hand-Hold/window switch assembly:
SOURCE: cant open right rear pasenger door 2005 pathfinder
i started by removing ashtray and the screw underneath. it would be easier to remove rear seat as access is not so good to move around. wind window down, then carefully pull from top of trim, it should come away fairly easy. the trim is held on by push in clips but you need to careful as they break easy. behind the inside door handle is a plastic backing plate which i found easier to remove first. now the outside handle can be undone and i simply pulled the cable and the door opened. the cable was broken where it joins the handle so a new cable is needed.
SOURCE: the door handle on my gmc safari has a broken door handle
You more than likely will have to remove the interior panel on the door which will be fun and take some time. Once you have it removed you should be able to manually operate the linkage and get it opened. I would be ready to locate a new panel just in case you break the original one, but they usually have some give to them if you take it slow. You might try removing the speaker also if you have one in the back door. It might give you enough room to use a stiff wire with a hook bent in it to operate the linkage.
SOURCE: side door handles are broken. rear door handle is
Hi Bluee
I am sorry but even though you provided a great answer your peers are no longer allowed to vote for you without fear of disciplinary action.
However on this occasion I will risk it for a biscuit
