When I turn on the set in the morning the right side is blurry with shadows under the words. The left side of the TV is fine Right side images appear washed out there are bars horizontal across the screen. After 1 to 5 minutes everything goes back to normal
SOURCE: 3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
SOURCE: Sony kdl-46xbr4 Black Horizontal Bands When I First Turn on TV
I had the exact same problem with the Sony KDL46XBR4. The problem started 11 months after I purchased the TV (Dec 2007). Luckily I placed the call to Sony just before the 1 year warranty expired and they replaced the entire front panel which is basically the whole TV except for the stand and the plastic frame. Last month the same issue started happening again (5 months since the repair). I called Sony and they say they have a 90 day warranty on the replacement part so I would need to pay out of my own pocket to first have the problem diagnosed (it's the EXACT same problem!) and then pay to have the repair done since the warranty has expired. I asked how much the front panel costs and it's $1,400! I paid $2,100 for the TV when I purchased it. Interestingly, at the time that part was back-ordered.....hmmmm, I wonder why??? Perhaps a recall is warranted here (no pun intended). Needless to say, I have sworn off Sony products due to their lack of support for this issue.
SOURCE: part of screen is blurry but goes away when it is
It under a year?Call Sony for warrenty repair,it ur Tuner signal board it have problems.
SOURCE: I have a Sony KDL-46W3000 since January
There isa problem in CRT Board.Loose connection problem in vertical section.Need for resolder the board.
SOURCE: When turning the TV on, the screen appears to be
It can be the T-CON board. Post pictures if you can.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
