Because the motor cannot spin.
Check the filter chute to see if a sock or somesuch is jammed in the blower wheel.
if there is no obstruction, you will likely need a new motor.Help Me Find My Model Number RepairClinic com
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob. I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
If the buzzing noise is from the vicinity of the switch, then suspect the push button contacts, if from within the bowels of the machine, then something is probably preventing the motor from running up to speed, it is stalled - (there are buzzes, and buzzes).This could be many things, from something mechanically jamming the drum, to worn bearings or a faulty motor/start circuit. As I am not aware of your skills, I am not asking you to take the back off and have a look.
