Click on the picture and then use CTRL+ to zoom in. Or if that does not work for you I will repost with different attachment.Click on the picture and then use CTRL+ to zoom in. Or if that does not work for you I will repost with different attachment.
You can't post conmments that contain an email address.
Jam in output bin - duplex area Error message
Jam
in output bin
alternates
with
Open
door and clear jam Description
Paper
jam in duplex reversing area Action
Clear the jam.
Press the (SELECT) button on
the control panel.
If the problem continues,
contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came
in the printer box for additional contact information.
Jam in output bin - fuser area Error message
Jam
in output bin
alternates
with
Open
A
paper jam has occurred in the output bin near the fuser area. Action
Clear the jam.
the control panel.
Three areas you need to check.1.Pick up area: While pick up roller picking up the paper,delay pick or no pick causes paper jam.. 2.Registration assembly area: Once paper picked from the tray, paper leading edge registered by the paper sensor located under the registration assembly.. In case this sensor dusty malfunction or flag damage, paper wont sense. result paper damage.. 3.Fusing area. If the paper travels up to fuser area, check paper jammed before entering in fuser(Teflon not rotating properly, replace teflon sleeve) or just crossed?(check paper sensors in fuser unit, clean the sensors & check flags,flag springs.
You will need to order a fuser and replace it or call a service tech who can. The problem is that the electronics on the fuser have actually burned out, so that is why the whole fuser needs to be replaced.
Just try the steps
Jam in output bin - fuser areaError messageJam in output binalternates withOpen door and clear jam
DescriptionA paper jam has occurred in the output bin near the fuser area.
Action
Clear the jam.
Press the (SELECT) button on the control panel.
Jam in output bin - duplex areaError messageJam in output binalternates withOpen door and clear jam
DescriptionPaper jam in duplex reversing area
Action
Clear the jam.
Press the (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
Sounds like you either have paper still jammed (maybe partial peice) in the fuser area or duplexing area. Open rear of the printer by removing the fuser in the back. Carefully check the fuser for paper and or damage to the sensor flag (small black flag in fuser paper path). Just in case you can't find it, I have included a link to the complete service manual that will walk you through inspecting and repairing the problem. Start on page 347 of the manual.
if it always jams at the same place (fuser area) try another fuser or check the BLACK PLASTIC ASSY. THAT is mounted in the left door and takes the paper right after it comes out of the fuser ;part is called (PAPER DIVERTER) And sometimes one of the FLAPS That routes the paper is broken,hence causing paper jam.
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
13.01.00 (HP 3500) 13.20.00 (HP 3700)
Description
A media delay jam has occurred in the registration area.
Action
Check for media stopped or jammed in the area of Tray 1 pick-up, Tray 2 pick-up/feed, and Tray 3 pick-up area (if Tray 3 is installed). Remove any media and continue printing.
13.02.00 (HP 3500) 13.20.00 (HP 3700)
Description
Action
these are areas that you mentioned and fixes to them
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478#A3
this is the link to all error codes for your printer you might want to print these out and keep safe
