Question about Pride Jazzy Select 6 Indoor Power Wheelchair
Jazzy goes right when full speed
When put in full power jazzy pulls too the right
Posted by thomas Morgan on
1 Related Answer
Anonymous
  • 39 Answers
SOURCE: the jazzy 1113 will not start, when you press the
How old are the batteries? If you've had them for a few years it might be time to change them. Even if batteries are charged correctly they eventually lose power with use and need to be changed. Here is a link to the battery needed for the Jazzy 1113 http://www.replacementupsbattery.com/UB12350-NB.html
Posted on Nov 11, 2010
How do you reset the chair when all the lights are flashing?
Hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
May 30, 2014 | Pride Jazzy 1103 Ultra Standard Power...
Can i lock the controls on my jazzy 1121
This is taken from the owner's manual from the 1121 with a VSI controller:
I suggest you print this out and keep it handy.
Locking/Unlocking the VSI
lock your power chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple up and down.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked.
NOTE: If the above procedure fails to either lock or unlock the VSI, contact your authorized Pride Provider.
Jul 01, 2012 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Forgot how to unlock power chair
This is the procedure to unlock the controller on a Pride Jazzy:
To lock the VSI:
To unlock the VSI:
Jun 30, 2012 | Pride Jazzy Select 6 Indoor Power...
Unlock a lock-out control panel for a jazzy 614hd
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple side to side.
Hope this helps
Apr 12, 2011 | Pride Mobility Products Health & Beauty
Replaced batterys in jazzy chair speed indicator keeps blinking - no code for it - plug in charger works for a minute after unplugged but then goes back to blinking?
Jazzy is in lock mode try the following to unlock:
Lock Mode
To unlock the VSI:
Hope this helps
Mar 29, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
The jazzy 1113 will not start, when you press the power button the speed light comes on gets full and then turns back off
Nov 08, 2010 | Pride Jazzy 1113 ATS Indoor Power...
How do you dial up the speed on the jazzy select 6
jrw if you are asking to increase the programmed speed of the chair then you need a programmer (a PP1) that will allow uo to increase the factory speed. But it's probably set at 100% already. Other than setting the speed on the joystick to full and changing the programmed speed will you be able to get the chair 's speed increased Hope this helps you
Oct 17, 2010 | Pride Jazzy Select 6 Indoor Power...
Have a jazzy 1113. The speed profile lights flash then the chair shuts off. The batteries show full.
The flash of the speed lights indicate that you are in the charger inhibit mode and if the charger is not plugged in then you have a problem that needs to be checked by a tech or your provider that sold you your chair Sorry I don't have a quick fix
Sep 25, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Power good, but no motor functionality - Jazzy Select
hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked
Jul 04, 2010 | Pride Jazzy Select 6 Indoor Power...
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
189 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
