How to replace the bag on a euro-pro shark plus ep 3005 vacuum
SOURCE: Shark Euro Pro upright vacuum V1310RS
Most vacuums you either remove the bottom plate, or the top cover comes off. If no screws on the top cover, then turn vac. over and remove the screws on the bottom. Then you should be able to get to the brush roll and belt.
SOURCE: Changing A Belt on Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=656349
Generic problem for all Vacuums
Changing a Belt on Vacuum
Posted by cnjk on Jun 08, 2008
Can you give me directions on changing a shark Euro-Pro UV219CS vacuum belt?
Thank you.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Shark vacuum cleaner belt is a side driven belt and you need to remove the bottom plate and remove the belt and place the new belt on the pulley side of the brushroll and make sure the ends are the same, insert the brushroll and then use a belt puller or screwdriver with a bend on the end and then stretch the belt onto the motor pulley and the track it in a straight line, replace the bottom plate. If you need further assistance please fee free to contact your local vacuum cleaner dealer in your area. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sharkvac.com/ Customer Tech Support 1-800-798-7398
These are the other brands that use the same tech support line
Shark / Euro-Pro / Infinity / Bravetti / and Fantom
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: Shark euro-pro x upright vacuum that shuts down every 15 minutes
These are prone to overheating. The manufacturer put a foam 'filter' wrap around the electric motor. This filter wrap insulates the motor, trapping heat inside, which causes overheating. The motor is very similar in form and function to the one in the Hoover Windtunnel, but the Windtunnel has no filter wrap. It doesn't overheat, and functions fine without it. There is a filter on the intake anyway. It's a redundant filter, and I have removed mine. It works fine now.
If you take the filter out yourself, you will need a special screwdriver for one of the motor cover screws. I guess they don't want the consumers opening it up.
I suggest taking it to a vacuum repair shop and explaining to them the problem, and asking them to remove the filter wrap from the motor.
SOURCE: Shark Pursuit Euro-pro X vacuum cleaner, 12 amp, upright model
This vacum cleaner is equipped for auto shut off when it gets hot , It gets hot when it gets clogged either the little sponge filter is to dirty or the the round white filter in the dust collecting container.
But if they are both clean then it is clogged in the line probably with lot of carpet fiber, in that case you ned to take the dust container out and possibly the assembly from bottom like when you change the belt, then take of the Handle where the flex hose is attached, then you gonna need a wire hanger bend a long shape close to the shape of the hose line from handle to where it curved around in the bottom opening where it collects the dust behind the spin brush the just stick the hanger from the handle side cause the clog is probably in the lower side then just push the clogs out . Be care full not to puncture the flex hose with hanger. Its probably a good idea to bent the tip of the hanger so that it wont poke hole in the flex hose.
That's what happened with mine I spend hours and hours and days to figure it out. I could have just through it away, but it just kind a pissed me off and the War was on as stubborn as i am, but finally I won and I got the satisfaction of the sweet victory.
Waste lot of time though but it just one of those things. It never messed with me again.
But that is what's wrong with it. Good luck it a good vacum though very power full.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
