Question about Toshiba Satellite A105 Notebook
LAPTOP NO DISPLAY, POWER OK
Posted by emmanuel saligumba on
Anonymous
The screens shorted out you need to send it to toshiba and have them replace/fix it
Posted on Dec 01, 2007
Acer extensia 5310 laptop working but no display
Check the GPU by plugging an external display in then power up the laptop. If OK, there is a fault with your display screen and it may need replacing.
Nov 12, 2014 | Computers & Internet
Acer as3810t no display
OK, best thing to do is test the external video port with a desktop monitor. The laptop will have a Fn key (function) commonly blue in color. The display icon in conjunction with the Fn key will switch between the 2 displays. Common issues with laptop displays is the back light inside the LCD display of the laptop. Power on laptop in a dark room and sometimes you can see the display, just slightly.
If you can see it, replay or have somebody replay the back light in the display. Was This Helpful? Yes OR No *Please vote yes if this helped you
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Apr 07, 2014 | Computers & Internet
Laptop is on but show as black screen
HELLO, DO NOT WORRY,THIS PROBLEM MIGHT EITHER BE A SOFTWARE PROBLEM OR HARDWARE PROBLEM,BUT WHEN YOU SWITCH ON YOUR SYSTEM PRESS F8 CONTINOUSLY AND BOOT IN WITH THE LAST KNOW GOOD CONFIGURATION AND SEE WHAT HAPPENS.IF IT IS A HARDWARE PROBLEM IT CAN EITHER BE THE RAM, SCREEN, VGA ETC
Nov 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
Nx5000 hp laptop no video
Power on the laptop and immediately tap F1, if the BIOS display comes up the hardware is ok, else the display has gone bad
Apr 12, 2010 | HP Compaq nx5000 Notebook
I have sahara laptop model no al 096 i want to install vga for dual monitor
i have sahara laptop model no al-096. i want to install vga driver.which driver prefeered to install in this latop.
Nov 08, 2009 | Dell Dimension 8300 PC Desktop
When I turn on my laptop it goes on but the screen is black and it seems locked up. Tried control, alt, delete and turning off and on but nothing works.
in stead of alt crtl del try pressing F8 key on keyboard after you turn it on, it will display a few options. go from thee.
in case it does not stars, you may have a faulty memory ram. it needs to be replaced
Oct 07, 2009 | Computers & Internet
Powering on the laptop does not turn on the display at all.
Most laptop screens connect to the motherboard(and therefore to power) through a small cable which generally runs very close to the hinge on the right hand side.
This cable can come loose.
If your laptop appears ok in all other ways this might be the issue.
Just plug a normal monitor into the back and youll see if the laptop itself is working ok.
To reseat this cable involves opening up your laptop, which I wouldnt recommend if it is still in warranty or if you're not too sure of yourself
Jul 24, 2009 | Dell Dimension 2400 PC Desktop
I WANT LG DRIVERS MODEL LGR40
LG LGR40 laptop has no display. Cooling fan works. Processor and VGA chips heat up normally. Indicators are also ok. Power supply is ok. Anyone can suggest a chip level based repairing of it?
Jun 14, 2009 | LG E500 Express Dual Series Notebook PC
Packard bell easynote l4014 display
Right-click an empty area of the Windows Desktop (your main screen). Click Properties, then the Settings tab. Under the slider labeled Screen area or Desktop size, slide the slider and click apply until you find the size that takes the fuzziness out of your laptop display.
Hope This helps!
Jan 23, 2008 | Computers & Internet
Toshiba Satellite A105 Notebook Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
