Question about Amazon Kindle Fire HD
My kindle is reading "authentication problem" and is not connecting to wifi which is in full range.
Posted by Denise Farrell on
  • Repairlass1989 Oct 22, 2019
    Try put it at side of router and put your Wifi password in it should work I had same problem
3 Related Answers
NinaE
  • 3278 Answers
SOURCE: After browsing with my kindle (3g wifi) in "aricle
Hello.
Reset your Kindle.
There's a little hole inside the battery cover area. Put in a pin or paperclip end and press. The Kindle should unlock.
Hope this helps.
Posted on Nov 10, 2010
TechyDrood
Justin
  • 2072 Answers
SOURCE: trying to connect kindle fire to wifi TheGriswalds has come up but do not have password help
Ask someone for the password, or if this is your router then you may need to factory reset the router and setup a new password
Posted on Dec 08, 2013
Richard Lane
  • 127 Answers
SOURCE: My 4 year Kindle won't stay connected to wifi.
Probably location from Wifi router. I know some of the areas of my older home don't receive a good signal. Check your wifi bars and see if this is a problem due to only one green bar showing as a connection. Rich
Posted on Jan 18, 2015
I am having a problem with connecting my Kindle Fire to the Wi-Fi. When I try to sign in, it keeps telling me authentication problem. I can't get past this answer. Please help me.
WiFi pass word incorrect or there is an issue with the WiFi router. Check password...make sure exactly the same including capitalization. Try resetting WiFi router.
Oct 08, 2016 | Amazon Kindle Fire HD
My kindle touch wont connect to my wi fi keeps saying incorrect password when i have not changed anything
Can you connect other devices to your wifi using the same password?
If so, it is the Kindle at fault.
Go to your wifi connections in Settings and remove your connection (I think it may say "forget").
Turn off your Kindle by holding down the power button for a full 30 seconds.
Restart your Kindle and connect to wifi, re-entering the password on the back of your router.
Mar 04, 2015 | Tablets & eReaders
Turning onto internet I get a white box up with retry o I have Got all the wifi settings up on the screen and underneath my TalkTalk_wifi number there is a sentence saying AUTHENTICATION PROBLEM ?
If your Kindle is not blacklisted, and the dialog box states that you have an authentication problem, then your Kindle is not connecting to your local network. Sometimes this can be caused by chip failure on the Kindle mobo, but usually it is due to an external network problem. You should try again once or twice and then if you continue to experience the problem, try to reset your local router by turning it off and on.
Feb 28, 2015 | Amazon Kindle Fire HD
Authentication problem when trying to connect Kindle to internet
go into settings and select wifi a list will pop up select and connect
Mar 01, 2014 | Amazon Kindle Fire HD
Kindle say authentication problem when trying to connect to wifi
Im sure you would have typed wrong password. please make sure you have correct password typed.
-regards
Why does my tablet keep saying authentication problem when trying to connect to wifi
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Dec 30, 2012 | Archos Arnova 10 4GB 4)
Amazon Kindle Fire HD Logo
575 people viewed this question
Top Amazon Tablets & eReaders Experts
Ron Rak
Ron Rak
Marvin
Marvin
Jean Thiebaux
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
