Sewing Machines Logo
Lynn Sammetinger Posted on Oct 09, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I correct stitch length mechanism to produce 6 stitches per inch?
When stitch level is placed all the way down at the bottom at 6 stitch indicator it sews a shorter stitches 10 to 12 stitches per inch. I need this longer stitch length to baste. Can you make any suggestions to fix?
R.A. Ellis
Level 3:
  • Sewing Machines Master 12,731 Answers
  • Posted on Oct 09, 2016
R.A. Ellis
Level 3:
Answers
12731
Questions
Helped
2619035
Points
59176
If your machine was manufactured to produce 10-12 stitches at the most, that is pretty much what you are stuck with. Some machines (ie, some Berninas) were made to produce a basting stitch which causes the needle to not complete a stitch or a couple of stitches in a row that will create a basting stitch.
You may be able to decrease the upper tension to create a gathering stitch that can be removed by pulling the bobbin thread.
It may just be easier and less expensive to buy working older sewing machine that has a longer stitch selection. Look on Craigs List and other for-sale sites for an inexpensive solution.
Bill Boyd
Level 3:
Top Expert:
  • Sewing Machines Master 53,816 Answers
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949218
Points
172802
The stitch length is governed by the cam action connected to the walking foot
that means that the stitch length is governed by the amount of material that is pulled through in the period of time that the needle comes up and goes down
normally the cam action is set by the stitch length lever/ reverse lever
if there is a necessity for a longer stitch, the cam would have to be changed on the drive shaft underneath
That will require a discussion with a sewing machine mechanic to determine if there are cams or other linkages that can be fitted to alter the stitch length for the manufactured maximum
1helpful
I have a singer treddle machine. I forget which way to turn adjustment to make stitches smaller? Have original book somewhere, even a copy. No luck finding them. Righty tighty or lefty loosen?
The following should help your memory. Regulating the length of the stitch: The machine can be adjusted to from six to thirty stitches per inch, as indicated by the numbers on the stitch indicator plate. Changing the length of the stitch is accomplished as follows: Loosen the stitch length stop control (B, Fig. 12) and move it to the bottom of the slot. Move the stitch length lever (A, Fig. 12) to the desired stitch length. Now, move the stop control up until the control plate (visible in the stitch length slot) touches the bottom of the stitch length lever. Tighten the thumb screw (B) with finger pressure only. At this point, the stitch length is "marked," and you can move the lever up to sew in reverse at approximately the same stitch length, and then return it to your desired forward length. If wrong instructions <?>, find your model... http://ismacs.net/singer_sewing_machine_company/manuals/singer-sewing-machine-manuals.html
1helpful
New project call for stitch length of 12. Is that about a number 2 on my 153 machine
The 12 probably refers to the number of stitches to an inch, so probably a 2.2 to 2.4 may be sufficient. A setting of 2.5 is probably closer to 10 stitches per inch. Twelve stitches per inch is good for most garment stitching. The stitches are not too far apart to allow popped stitches under stress and gapping between stitches nor too close together that would make it difficult to remove stitching when correcting a mistake.
https://www.quiltingcompany.com/understanding-stitch-length-quilty-pleasures-blog/
https://www.google.com/search?q=sewing+machine+stitch+length+gauge&ie=utf-8&oe=utf-8&client=firefox-b-1
Does a Brother VX877 sewing machine sew a straight stitch. If so how do I set it up?
The average stitch length is 2.5mm. This is the typical setting on newer sewing machines. Older machines usually give you a range of about 4 to 60 which tells you how many stitches per inch; the equivalent of 2.5mm is about 10-12 stitches per inch. The smaller the stitch length number, the smaller the stitch.
https://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hf_se600eus&faqid=faqh00101023_000
What setting do I use for blind hems on Viking 183
Select the blind hem stitch. Be sure to have the correct presser foot. Then set the stitch width so the "zag" will catch the fabric fold and set the stitch length so there are probably about 10-12 stitches per inch.
I want a 1.8 stitch length to paper piece ... I can't figure out how pfaff creative changes to 1.8
Looks like your machine's stitch length ranges from 0-6 mm. So you are looking at something just under 2 mm--there very possibly is a 1.8 setting on your machine. Basically, your paper piecing instructions are telling you to set the machine to stitch somewhere between ~12 to 14 stitches per inch. The accuracy of 1.8 is Not that important. What they are trying to do is make sure your stitches are close enough together to make it easy to tear away the piecing paper. When using longer stitches for paper piecing, it is sometimes difficult to tear away the paper without pulling the thread stitches. Most garment stitching is set between 10-12 stitches per inch. So you want something just a little closer together, ie more stitches per inch. If you are concerned, try it out on a scrap piece of paper and fabric and try tearing it away. If it works, then that's all you need to use.
Setting Stitch Length Quick Look at How and Why Sew4Home
1helpful
How can I adjust the stitch length on a Singer 111W155?
To adjust the stitch length, press down on the plunger on the base of the machine. It's to the right of the needle and towards the back. While holding the plunger down, rotate the pulley until the plunger enters a notch in the the adjustable feed eccentric cam (visible on near the center back on the bottom of the machine). Then adjust the pulley forwards or backwards until the desired number of stitches per inch is visible in the stitch length window to the left of the pulley. Then release the plunger.
See page 14 of the manual which is available from Singer here: http://parts.singerco.com/IPinstManuals/111W152_W153_W154_W155.pdf . It's page 8 of the PDF. You will also need to look at Figure 2 on page 4. Figure 5 on page 4 shows the cam (J1) that the plunger enters when you can adjust the stitch length.
I hope this helps.
I need to know how to make a button hole, can't find manual.
Hi there, don't know your machine but you can do a plaiin buttonhole manually.
Set machine up for zigzag stitch, needle to left side, mark out the size you need with pins or marker pen. Start at the top and set for widest zigzag with 0 length for the top bar, cannot give sizes as don't know the button you are using, about 6 stitches, set stitch width to just over half the width of top bar and length to approx 0.5. Stitch down to bottom marker and again set up ffor the wide bar, do the same amount of stitches as the top, finish with needle down at the outside edge, turn work so that you will now stitch down the other side to meet the top bar, not forgetting to adjust stitch length and width again.
Hope this helps
Ellie
Ordinary straight stitching
When you turn on a #1 Husqvarna Viking the machine defaults all the electronic settings to do a straight stitch at a 2.5mm stitch length, that equates to approximately 10 stitches per inch. The top tension dial sets itself automatically and the only other dial is on the left side of the machine. That dial sets the pressure on the foot that holds down the fabric. It's normal setting is 6.
My stitch length is not what I have it set for. I set it on 5
I assume you mean it stitches 6 or 8 when set at 5.
Because the number shown on the wheel says "5" doesn't necessarily mean 5. It's just an approximation. You'll note that when turning the wheel there's tension. The numbers are just numbers. It isn't a micrometer, its a sewing machine. So, you can simply adjust to get the stitch you want then make a mark on the wheel at that point. You may end up between 4 and 5, or between 5 and 6. No matter. Wherever you get 5 per inch is where the adjustment is.
Not problem-question
Different stitch lengths are used depending on what you're sewing. I would say 2.5 is the "normal", "average" stitch length for basic sewing. If there are certain types of fabric you're using that ravel or come apart easily, you would use a smaller stitch length, which means more stitches per inch. If you want to just baste fabric together without having a permanent seam, you woould use the highest number, to have the least amount of stitches per inch.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
