Was changed the battery and unfortunately we lost contact with the previous car owner. Many thanks in advance. Kind Regards
SOURCE: philips car radio code
check for any factory code available. this happens when the receiver controller get reset. it takes that a service 1. so it asks for a factory code. contact authorised daewoo service centre for a code
SOURCE: PHILIPS CAR RADIO CODE
TOR058
model no:22dc 229/62T
prod no:FD0303140117129
RN229F30117129
LOST RADIO CODE AS NEEDED CAN YOU HELP
[email protected]
SOURCE: wat is the secerity code for unlocking your radio
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
SOURCE: I need the code for my philips car radio. MODEL: CAR400
Please
check your Serial Number again to make sure it is correct.
If
it is correct , then unfortunately your code will not be available for free (or cheap) from anywhere on the Internet as this Serial
Number is not in the available PHILIPS database.
It
requires access to the original manufacturer`s database which is only available
from your Main Dealer .(and a few of the larger Professional Radio Decode Specialists)
Otherwise
try a Decoding Service or your local Car Radio / Audio Shop who will
electronically "read "/ recode the memory chip (EEPROM) using a
laptop and specialist software.
