Go to the Google Play Store. Speak "keyboard" in the search. You should see an app for Google Keyboard 2-3 down. Make sure it is enabled. Once enabled you will be able to turn off Google Speech.
Sound like voice activation try and hold the volume buttons till it say talkback suspended press ok a few times quickly and then it will say talkback suspended
Go to your accessibility settings menu on your kindle.. 1) Tap and hold the top bar on the screen and then pull the bar downward to view the settings menu. 2) Tap more , to view additional settings. 3) Tap the accessibility option to open the access menu. 4) Slide the text to speech to off. 5) Slide the voice control to off. 6) Tap the back arrow to save your settings and to close nenu. Ellen
Triple click the home button. Then double tap the VoiceOver off button. This should allow the device to return to normal operation. Then you can reset by pressing and holding both buttons (power and home) until it resets if you need to.
Talkback is switched ON in SETTINGS/ACCESSIBILITY. In this mode to activate any button you must click on it 3 times. Once to select it and twice more to activate. Also use two fingers to swipe across the screen instead of one. Using the above method to access the SETTINGS app turn OFF Talkback.
