Question about Fisher Paykel EcoSmart GWL15
4 lights and beeping, nothing else
After pushing power on and start, the machine thuds three times, 4 lights come on and it starts beeping. A service man told me that it needed a computer, which the company quickly sent me and I installed. After doing 2 loads of wash successfully, it now won't work again. The machine is only 7 years old.
Posted by On the cape on
Anonymous
Check the out of balance switch which is located underneath the motor controller panel. It is a small rectangular flat piece with two wires going to it. If you see any corrosion then you will definately need a replacement part (which had fortunately been improved on since the original).
Posted on Jan 09, 2008
Anonymous
prem mathew
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 29, 2007
Gw712 doesnt start just beeps
Lets see if an error code pulls up.
With the machine off, press and hold the Wash Temp Down button and then push the power button until the machine gives 2 short beeps and lights up. Now press the Spin Speed Up button three times so that the Hold and Slow LEDs are illuminated.
The eight wash progress LEDs will show the error code.
Apr 29, 2014 | Washing Machines
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
Fisher and paykel smart drive 703 top loader, lights go on but pressing them even to start does nothing not start or let me change the size of the load ;(
Hi, just read your posting.Now the possible fault could be your display board.When you turn the power on to the machine from the power point do all the lights come on and you hear an audio beep beep , then the lights go out ?If that happens, then do you push start and can not select anything else like water temp or load size?Or do a series of lights light up and it beeps indicating a fault code after you have pushed the power button? Please reply and I can guide you throe step by step the process needed to fix this problem.
Jun 05, 2010 | Washing Machines
Washer beeps at the end of each cycle,must be advanced manually
Hi Steve just read your posting.Now when it starts to beep a series of lights will light up.Starting from left to right they are numbered 1st on the left=128 next is=64 next is=32 next is =16 next is= 8 next is = 4 next is = 2 next is = 1. So the lights are numbered from left to right 128--64--32--16-- 8-- 4--2--1. now with this information look at the lights that are lit add up the value of the lit lights and reply back and i will look in my service manual and tell you what part or parts are faulty. hope this helps.
Jun 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
LTF2140ES0 washer just beeps three times, wont start
Frigidaire engineers are so smart they programmed it to beep 3 times for door lock problem, draining problem and other problems in the internal electronics and didn't bother to give the users specific info to read off the machine.
Oct 30, 2008 | Frigidaire 14 Cycle Tumble Action Washer
All buttons cause machine to beep
Trying unplugging for 20 minutes maybe you can reset it.
Aug 28, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
112 people viewed this question
Top Fisher Washing Machines Experts
Mike
Alan Chouinard
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
