Question about Panasonic Lumix DMC-FZ30 Digital Camera
How do I fix the mode dial?
The mode dial has suddenly stopped working on half on the selections. How can I fix it?
All photos suddenly too dark, even using flash.
If you are sure you are in automatic mode, the green camera logo on the top dial, your pictures have to be correct.
The exposure compensation should not be available in automatic, so that can't be the reason. (if you are in automatic)
The only thing you could look for, is the exposure metering. There you can chose 3 modes, and I do advise to chose Multi-pattern (should be default) because then not only the centre is measured.
If the pictures stay too dark, while in automatic and Multi-pattern, i think your camera is defect. It has nothing to do with the battery. If the battery voltage drops beneath a certain point the camera will stop completely and not work half.
Feb 16, 2014 | Kodak EasyShare Cameras
Rca lab 1200
This is a belt drive turntable so it could be the belt slipping about. Before you remove the belt note where it fits.
Dec 25, 2013 | Audio Players & Recorders
Fluke Networks 42801009 Ts42dlx keypad and loudspeaker suddenly stopped working
some meters use a spring that makes contact between the two halves of the case, and often it is used as a ground for speaker & keys.
Oct 11, 2012 | Fluke Networks 42801009 Ts42dlx Set W/abn
The tone on my 2 portable DECT 6.0 phones was somehow changed- now every time I dial, I get the old rotary sound and I can not access any menu options. Help, I use my phone for work and need it fixed! ...
Your phone is somehow set to pulse dialling and you need to change it to tone. Instructions are given below.
Of course if you can't select menu options this will not work so please explain why the menu options are not available - what happens when you select the menu softkey?
Dial mode
The dial mode is preset to tone. If you do not have touch tone service, you need to change the setting to pulse.
To change the setting:
Press the MENU softkey when the handset is not in use.
Press or to select SETTINGS, then press the SELECT softkey.
Press or to select Dial mode, then press the SELECT softkey.
Press or to choose Tone or Pulse. Press the SET softkey to save, or press the BACK softkey to exit to the previous menu.
Feb 03, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Pvc selection keeps changing to dial up mode
  • delete the dial up connection on the internet option
  • click tools-internet options on the internet explorer - click connections tab, delete all dial up on the box, and select never dial a connection
Aug 04, 2009 | Siemens SpeedStream 2624 Router...
Only about half the modes work on mode selector dial
Sounds to me like the internal contacts aren't working correctly. Let your local camera store take a look. Hope it's under warranty.
Dec 03, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon eos 400d mode dial does not select modes
Looks like you need to take this to a camera store and have them check it over. I don't know of any setting that would cause what you describe.
Can,t connect my Plantronics220 Earpiece to my phone
Begin with headset turned off. 1. Press and hold down the call control button
for 8 seconds until the headset status indicator begins to flash blue then red. The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing, use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
Oct 13, 2008 | Plantronics Explorer 220 Bluetooth Headset...
How can I set tone/ pulse so I can dial out
Press menu and use the arrow down to goto Global setup and press select. Use the down arrow and goto Dial Mode and press select. Use the down arrow to select your dial mode and press select
Jun 01, 2008 | Uniden 5.8GHz Dual Cordless Phone
Gorenje WA1541 Washing machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
And pl rate me if helped.................
Jan 24, 2008 | Washing Machines
Panasonic Lumix DMC-FZ30 Digital Camera Logo
37 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
